Find the ratios for the lancer evo 1 - 3, the driveline is all identical.
Good luck making the engine fit the other way around :S
Hi,
Im looking at swapping around some parts from a new and later model Galant.
The older car is a 5speed Manual 4WD V6 2l Twin Turbo E84A Galant.
the newer one is a 4speed Semi Auto 1996 Legnum 4WD V6 2.5l Twin Turbo.
I have the legnum gearbox and transfer box (dog box)
Id like to change it all over to a manual gearbox..
now the problem is my final gear ratios...
I know what the following are... but I need to find out these valus for the E84A... PLEASE HELP!! ??
here is what I know up until now...
Magna 5speed Manual, Magna AWD, Legnum SA4, SA5 ,RALLIART Manual, Ralliart Semi Auto
1st gear = 3.583 , 3.789 , 2.842 , 3.789 , 3.333 , 3.789
2nd gear = 1.947 , 2.057 , 1.495 , 2.057 , 2.015 , 2.057
3rd gear = 1.379 , 1.421 , 1.000 , 1.421 , 1.407 , 1.421
4th gear = 1.030 , 1.000 , 0.731 , 1.000 , 1.031 , 1.000
5th speed = 0.820 , 0.731 , 0 , 0.731 , 0.804 , 0.731
Reverse = 3.363 , 3.865 , 2.720 , 3.865 , 3.416 , 3.865
Last reduction gear ratio = 3.722 , 3.684 , 3.744 , 3.684 , 3.736 , 3.684
So if you have the info on E84A Gear ratios please reply..
thanks
Haydn
1994 E84 VR4 V6
Single turbo conversion
Fulltime RWD w/ mechanical LSD
Fun times 8)
