<div class='quotetop'>QUOTE(ChuBBs)</div><div class='quotemain'>thanks i appreciate it!!! where can i get aftermarket struts? what about a camber kit?</div>
Try tirerack.com for the struts, for the camber kit I got the Intrax kit from a local shop... it was for the 97 Eclipse.
<div class='quotetop'>QUOTE(stormcruiser)</div><div class='quotemain'>
I am wondering about the camber kit.....I know that things fixes the negative tilt and stuff but theses stuff cost quiet a bit. If i am getting eibach which lowers 1.5 in front and 1 in the rear, I don't need em right? Hows other people? Did anyone got eibach or spring and got a camber kit? Â*
</div>
aahh, since this is going to remain at the top of this forum I guess we might as well cover it all then, huh.
I had Eibach springs before my Skunk2's, never bought a camber kit for those. The Eibach springs only cause about 1 degree of negative camber, in my opion, not worth correcting for $80 dollars. They offer it just to make the install perfect if you want it.
A 2-3-4" drop is gonna cause increasingly more negative camber, this is when the tops of your wheels point inward towards the car. The 7g only needs this correction in the back wheels, usually. This amount of camber will KILL your tires! It is best to correct it. They are expensive but so are new tires every couple thousand miles
