not sure. but im 5 lug with GSX rotors and swapping to dual piston fronts from a 3kgt. you need special lines.Originally Posted by Sleepervr-4
Has anyone tried to see if they work with the stock 15". I need a new calipher and was thinking why not upgrade to 2 pistons.
2000 Galant ES = Daily Driver
Is it true you have to swap right and left when installing? and could I just use 2g gsx brake lines?Originally Posted by Proto
Ive always been told that swapping 2g GSX calipers left and right and they will fit fine. Ive bolted up Diamante duel caliper pistons and their bracket and they fit perfectly. Just not sure if we need a bigger rotor to completely use the bigger caliper.
thats why i have GSX slotted/drilled rotorsOriginally Posted by seth98esT
So if I use diamante calipers and brackets I dont need to swap left and right?Originally Posted by seth98esT
different brake lines i believe, they use a male end and not a banjo bolt.Originally Posted by Sleepervr-4
some 2 pispton calipers had the straight fittings. some had the banjo fittings. they will both work with yoru stock setup as the line lengths are the same. would only make a difference when ordering stainless lines. just make sure that you use the lines that come WITH the caliper if you use the kind with the straight fitting.Originally Posted by Proto
then attach them to your stock hardline.
i ordered SS lines for a 2g with male ends for my 3kgt calipers.Originally Posted by DOHCstunr
Just wanted to give you guys an update on this subject. The other day I realize my boys 6g vr-4 has oem big brakes and is 4 lug. I am pretty dam sure those rotors would work on our cars.
i know you told me that you are runnign the v4 rotors and dual piston calieprs now.Originally Posted by Sleepervr-4
and i read that you were asking if they'd fit stock wheels.
so did they fit behind yoru stock 14's? or did you have to run other wheels?
I am running 17" rims and they fit. I never tried them with the stockers but if someone in the area wants to try them on my ride lmk.
I plan to do this soon... VERY soon.. (after all my problems are fixed)
I have 2 sets of the Diamante calipers, I really want to do this. I doubt the stock 15" wheels will clear, but Im positive 16" wheels will as thats what came on the majority of 1g/2g GSXs.
Now to find some nice 16" wheels for cheap and some good tires!
They will clear 16", I know that for a fact. Once DSM tuners comes up I'll post the link for dual piston upgrade.Originally Posted by seth98esT
Some 15's fit for example rota slipstreams. My boy has those on his eclipse and they clear the big brakes.
wow I have been workin on a vr4 3kgt and I am swaping the motor on it to a jdm one and the guy acts like he will not pay so maybe I will get those calipers and get the stoppin....
8g tranny is being rebuilt and waiting on ground control coilovers
7g is just sitting motor and tranny is out(need to finish, just lazy)
6g (vr4) motor is out getting the good stuff like a gt4088 and some more stupid stuff.
Nice to be back!!!!
I wonder if the 15" Lancer OZ wheels would clear. Id like to get a 16" set of Rota Torques for dailey use and some 15" Lancer OZ wheels for AutoX.Originally Posted by Sleepervr-4
Heck, I have the brakes, I may as well try to bolt them up this weekend and see if my stock 98 15" alloys clear.
as all of you know, i have an 8g v6 which has the dual piston calipers. similar setup to the 2g gsx. same rotor size even. but yea, 15's will clear but you have to make sure u don't knick the caliper paint when u put the wheels on. with that said, i should repaint my calipers lol
3000gt vr4 ones wont work but but 3000gt sl ones will.Originally Posted by T-double
