18x8 with a 45mm offset
Am I gonna have alot of trouble out of that setup I am on Tein SS-P. Thanks
They'll fit.
Depending on tire size and how much drop you decide to use with the Tein SS-P dampers you may need to roll the rear fenders.
Thanks man do you know if they will stick out any? I know my 7.5 in wide wheels sit perfectly flush. Thanks
<div class='quotetop'>QUOTE(02galant)</div><div class='quotemain'>Thanks man do you know if they will stick out any? I know my 7.5 in wide wheels sit perfectly flush. Thanks</div>
Most likely not, there is a .25" difference in width on the outside, and .25" difference in width on the inside (which obviously your won't see).
