Ask Matt...uh...Peano
i got my new CF hood, and the new hood pins, can you guys tell me what type of drill bits i should use to drill through the carbon fiber, i know that drilling through carbon fiber can be very tricky, or is there anything else i have to use to drill through the hood, or what should i look for...any good comments please post..thanx
jake
2009 Mitsubishi Lancer Ralliart
JDM 5 SPEED 4G64
TO GET TO A MAN'S HEART....IS THROUGH 4G64 egh and may be through 4B11T
just used any old drill bit. for shaping the holes to perfectly fit the pins you want to use a dremmel but make sure you don't take off too much material
start with a small bit first and work your way up. it will be easier on the hood that way.
