Thread: Trunk won't open when lever is pulled.
Showing results 1 to 7 of 7
    Member
    07-16-2006
    Los Angeles County.
    186
    All of sudden the lever that you pull to open the trunk isn't working. It was working fine before. What could have caused it to malfunction and how do I fix it? Thanks.
    - 2002 Sentra SE-R Spec V (stock)
    - 1999 Mitsubishi Galant V6 (auto)
    "In the past, God overlooked such ignorance, but now He commands all people everywhere to repent. For He has set a day when He will judge the world with justice by the Man [Jesus Christ] whom God appointed. He has given proof of this to all men by raising Him from the dead." Acts 17:30-31.
    there are springs in the mechanism that release the latch to the trunk that are connected to the lever inside the car.
    check the lines from the lever to the hatch, you will find one that has been disconnected. you might have to pull one of the springs over the notch where it should be connected. your cable may have become detached from the lever as well.
    i took mine apart, so that i can only open my trunk with the key. keeps things in there safe and sound... for the most part
    Member
    07-16-2006
    Los Angeles County.
    186
    Thanks for the reply, but the stranges thing just happened. It works again. My g/f had moved the seat up so she can reach the pedals and it the lever wouldn't work. So I pushed the seat back to my usual position, and pulled the lever and it worked! This is strange :?
    maybe when she moved the seat up you couldnt pull the lever enough to release the latch..... dunno.... ?
    if it works - done. and done
    isn't there a swtich near the actual trunk latch that disables the lever up front? it's like the child safe switches on the rear doors which deactivate the the rear inside door handles...
    Member
    07-16-2006
    Los Angeles County.
    186
    <div class='quotetop'>QUOTE(Reelax)</div><div class='quotemain'>isn't there a swtich near the actual trunk latch that disables the lever up front? *it's like the child safe switches on the rear doors which deactivate the the rear inside door handles...</div>
    Yes, I saw that switch. It says "Free" and "Lock." But that didn't help either. Apparently, the trunk release lever is affected by the position of the driver seat. It works fine now. I just told my g/f to move the seat back is she uses the lever. Kind of a hastle, but atleast it works.
    01-24-2005
    DFW/Stillwater
    2,751
    when that happened to me, it was because my trunk latch failed. my old trunk latch is a failure
