Page 10 of 19 FirstFirst ... 67891011121314 ... LastLast
Showing results 181 to 200 of 376
  1. #181
    Kansas City, MO
    1,244
    actually i was thinking it was a SOHC 4g64 block with a 6 bolt crank, not even DOHC?... haven't seen any DOHC's but i really haven't been looking
  2. #182
    A SOHC wouldnt be cool. But a 6bolt 2.0L crank in a 2.4L 4g64 block would give you a 2.1L destroked reving monster haha. Would be good for a bigger turbo that spools 4k+ as with a good head you could rev to 9-10k :P
    But if your going to put a 6bolt g4cs crank in a 4g64 block, may as well just go ahead and use the g4cs block instead of the 4g64 block.
  3. #183
    Kansas City, MO
    1,244
    Well i was referring to him asking about the DOHC sonata engine, and i haven't seen any. as for me i'm not looking for a g4cs. all i want right now is a workable head for my other engine
  4. #184
    Quote Originally Posted by Blue Ice
    Are you looking for a SOHC or DOHC, because i have an extra 63 head if you want it.
  5. #185
    The g4cs is a SOHC motor anyway. It shouldnt be hard to find a 1g/2g head, they are all over the net :)
  6. #186
    Kansas City, MO
    1,244
    are the heads the same between 1g and 2g? never really knew if there was a difference between heads, i knw there is a difference between blocks
  7. #187
    1g head flows more. Has bigger intake and exhaust ports.
  8. #188
    08-18-2004
    Charlotte, NC
    1,029
    You sure? Pretty sure it uses a coil pack setup.
    I thought so too but when I was looking up different models of sonatas, the results mention ignition coils, distributor caps and rotors for the year 92-93. I did came across something interesting.
    1994 GS FYI
    DSM/CSM Manuals
  9. #189
    phizz2k
    Well this topic has been in the back of my mind for a bit now, but I had an idea that could possibly make the "easy swap possible"
    There is a shop named budsmachine.com that dropped into gf and asked if anyone has done the swap and how they fixed the distributor problem... A few moments later he posted that he machined something to make it work...
    I emailed his msn account ([email protected]) and visited there website which looked to be a very professional shop... Haven't got a reply yet but if other members here are still interested in making this happen then an email or a visit to the site could help us get this project rolling....
    Just a thought...
  10. #190
    quite intriguing ... I'll have to check out the site, good find.
  11. #191
    I looked at that honda-tec, the only thing about that is by the time you bought the parts(unless you allready have the ems and things) it would be cheaper to go ahead and swap the ecu and cam angle sensor. I know some people allready have ems and this would work for them but i would rather swap the ecu since i wouldnt have the money to drop, but to each his own.
  12. #192
    phizz2k
    Quote Originally Posted by bmxmike
    honda-tec ???????? What do you mean. There aren't any prices on this site.. who knows how much it will cost... I may give em a call and see if it's possible....
  13. #193
    He has a parts list though and i know for the engine mangment systems those are usually higher end of price range. Cause using the ems he has it costs around $1,200 im looking around to see if i can find any system under $1,000 cause i dont belive that the emanage can do the cop
  14. #194
    phizz2k
    OK, I understand that they could have used an ems to correct the addded changes that come along with dohc but still didn't see any prices...
    What information would you use to rewire and swap your ecu?
  15. #195
    Well this forum is so you dont have to rewire you ecu. Because if you do a DOHC swap you need a new ecu to run the cam angle sensor cause the normal ecu uses the distributor. On the ecu swap you just take out your ecu and then just rewire your wiring to the ecu. Theres tutorials on it.
    As for the ems way. You hook up the ems system and set it up, then you hook up the C2DI(Digital Ignition) too it and wire up each of the coils to the C2DI.
  16. #196
    Im confused, what Honda-tec? Who did this swap? Its by far cheaper and easier to run a Galant GS or 2g Spyder GS ECU then to go all out EMS.
  17. #197
    Thats what im saying unless you can actually find a distriuptor for this swap it takes away from the whole thing, cause then you doing as much work as swapping the ecu.
  18. #198
    You really confuse me man lol. ECU swap is by far easier and less complex then going all out EMS. And thats what this entire thread is about, trying to find a distributor that will bolt up to a stock 1g/2g head so you dont have to swap ECUs.
  19. #199
    no thats what i was saying that using a ems is too expensive and more complex. Considering the cost for most ems that will work for this are above $1,000. Ecu swap costs tons less and if you decided to go turbo you can go to turbo ecu and take use of the knock sensor
  20. #200
    phizz2k
    Ya Bmxmike your kinda confusing things, and assuming that the ems would cost upwards around $1000.00 bucks but I don't think the person that paid these guys to do the swap would have given up that much money when he could of used it do do a motor swap or turbo system instead....
    All I was saying is these guys may have a part already drawn up to machine because they say they were able to machine a distributor to fit into the 4g63 dohc.....
    I found this information here =>
    http://www.galantforums.com/modules....iewtopic&t=232
