Page 6 of 19 FirstFirst ... 234567891016 ... LastLast
Showing results 101 to 120 of 376
  1. #101
    08-06-2005
    Long beach/ guam
    1,585
    so how's the ride on it?? working good?? no probs?
  2. #102
    good point on that, i think he was just messing with us, i wont belive nothing untill i see some pictures and there better be no photoshopping them either ha hahahahhahha. but please if any one has access to a 1g or 2g head and has the available parts try it and see if it works.
    2009 Mitsubishi Lancer Ralliart
    JDM 5 SPEED 4G64
    TO GET TO A MAN'S HEART....IS THROUGH 4G64 egh and may be through 4B11T
  3. #103
    07-20-2003
    Orlando, FL
    3,169
    <div class='quotetop'>QUOTE</div><div class='quotemain'>if any one has access to a 1g or 2g head and has the available parts try it and see if it works</div>
    I have the parts. I already tried a 94-95 distributor on the DOHC head and it doesn't fit. Tonight for sure I will be testing if the 96-98 distributor will work on the DOHC head which I HIGHLY doubt it will. Pics will come very soon.
  4. #104
    Kansas City, MO
    1,244
    when you test it. Can you also check to see if it will fit if a spacer, or mount was made? i see what you were talking about with the how the dist is mounted to the sohc. I think it would might fit if there was the same kind of mount on the dohc.
  5. #105
    07-20-2003
    Orlando, FL
    3,169
    Quote Originally Posted by Blue Ice
    I get what you are saying and actually if the distributor shaft was alot shorter, it would match the mounting points as the DOHC CAS would. The other issue though is the diameter of the distributor, its much wider than the opening on the DOHC head. Oh well...i'll just post pics, they will explain ALOT better than I could. :-?
  6. #106
    well lets see how it all turns out, ill check to see if the hole in my DOHC head is big enough to fit the distributor
    1994 GS DOHC 2.4L 5spd (For Sale)
    1996 S SOHC 2.4L 5spd (Up and Running)
  7. #107
    Yah I think this guy is joking with us! Im sure the concept will work, whether or not you will need some sort of spacer made, thats another problem. Any descent machine shop would be able to make one for you, price is where it may or not be worth it. Probably &#036;50-200 to get something like that machined from a block of aluminum.
  8. #108
    12-17-2002
    Sherman Oaks, California
    4,304
    i wonder if he did the headswap and his car blew up the next day and he's just been too busy dealing with that to post up
    http://socallifestyle.com/
    1994 Galant GS 5spd
  9. #109
    07-20-2003
    Orlando, FL
    3,169
    Quote Originally Posted by peanotation
    He was last signed on Yesterday at 6:12pm :-|
  10. #110
  11. #111
    Bronx NYC (reppin)
    3,489
    Quote Originally Posted by jjmoneydawg
    pics or ban!
    LOLOL. Flame on! :firedevil:
    Drive It Like You Stole It!
    7G Erubini Body Kit for sale
  12. #112
    12-17-2002
    4,304
    pics or i'll come to your house and start raping the women
    1994 Galant GS 5spd
  13. #113
    Bronx NYC (reppin)
    3,489
    Ya i will strip the car and Peono will tie you up, and like STAR said we will put er on the strip to make us some turbo money! lolol
  14. #114
    Proto
    what women? he probaly lives alone.
  15. #115
    07-20-2003
    Orlando, FL
    3,169
    I got a chance to take some pics today of why I say the distributor DOHC isn't going to work. Sorry for the delay..I have been packing for the past several days and getting ready to close on the house. I will try to get the pics posted tomorrow.
  16. #116
    Member da1085's Avatar
    01-03-2006
    202
    i've been keeping up with this thng for a while and i think this guy should be ban for pulling our SOHC chains
    does the 1.8L eclpise use coil packs?? if they dont, they must have a smaller distributor than our 2.4L motors...maybe it might fit on the DOHC from a 2G eclipse and since we'll be using them for our motors hen we might be able to use the 1.8 rotors....well since the stock distribtor is too big for the DOHC.....the only thing the ecu needs is to know when to fire right?? i dont know, maybe im wrong...
    im hopping that the 1.8L doesn't use coil packs since if they do i just wasted time writing this reply.
    or maybe even the 1.5L mirage.....
    1990 GSX(91 eprom ecu set-up)
    6-bolt jdm (GVR4)
    16G turbo
    3inch turbo back(flowmasters)
    510cc
    OSTRICH
    FMIC
  17. #117
    seth i think you should ride to his house, and check insidce his garage!!! he lives in the same state as you!!!! HOPEWELL VA i think, dont know how far but same state!!
    JDM 5 SPEED 4G64
  18. #118
    Theres 3 HOPEWELL, VAs here! One is 2 hrs, 3hrs, and 4hrs from me ha!
  19. #119
    damn .................
    JDM 5 SPEED 4G64
  20. #120
    01-03-2006
    202
    ok......i looked at some pctures from a 93-95 1.8L mirage and compaired it towards the Eclipse CAS (picture posted about a page ago) and they look really similar
    i would try this match up in the yard but i have no acces from one since im stayin at my dorm in san marcos, texas......WHAT DO YOU GUYS THINK??DOES IT HAVE A CHANCE?
    6-bolt jdm (GVR4)
    16G turbo
    510cc
    OSTRICH
    FMIC
