here's two tutorials that should sum up a big chunk of it.
http://www.k-lanandreajoy.net/Tutorials/radio/
http://www.k-lanandreajoy.net/Tutorials/radio.pdf
running the power wire is similar to running the signal wires. instead of starting with the back of the radio, you start at the battery, go through the firewall and from there its about the same.
running the speaker wire from the amp to the front speakers is again almost the same as running the signal wires, but you start at the door, go through the door grommet and from there its pretty much the same
let me know if you need more help, i know a bunch of that stuff off the top of my head.
