You'll have to remove the intake plenum to replace the plugs on the V6. There's a tutorial buried in the garage section. As long as you have the plenum off, change the spark plug wires at the same time. You should be able to pick up a set of NGK Platinum plugs and NGK wires for around $70. I just replaced mine last week. go to www.sparkplugs.com. They're a major NGK resellerOriginally Posted by jhendra83
