Thread: car overheats when in park!!!!!!!
Showing results 1 to 19 of 19
    Ok, lil problem.
    When im in drive, driving, or even at a stop, car runs fine. As soon as I put it in park, after about 10 minutes, temperature gauge starts rising higher and higher, like the car is overheating.
    Anyone has any clue if its a serious problem, is it common, how can i fix it.
    Thanks.
    by the way, its a 2000 galant es, 4 cyl.
    not jacking your thread, but i'm having the same problem. even when im in D and sitting still at a light temp gets hotter and hotter. but if i put it in N and give her a lil gas then it goes back down... :shock:
    lasthopeskrispy (9:45:12 PM): what would a computer do with a lifetime supply of chocolate?
    SkylineGTR7865 (9:45:36 PM): idk what
    lasthopeskrispy (9:45:47 PM): fuck if i know
    01-19-2007
    Clifton, NJ
    3,471
    :smt017
    That's wierd...
    any smoke?
    no smoke, no symptoms other then gauge going higher up to H
    01-19-2007
    Clifton, NJ
    3,471
    does it go all the way to the line?
    not really, as soon as it sratrs going up, bout 3/4, i either turn the car off, or drive off. Dont wanna completely overheate it, or have my radiator bust.
    hows your fluid? properly filled? in good condition? mixed properly?
    Bronx NYC (reppin)
    3,489
    check your fluids, make sure you have the right mixture. It could also be your thermostat or temp sender, maybe air in the lines also.
    in any event the temp starts rising, just turn on the heat full blast till it starts to descend.
    Drive It Like You Stole It!
    7G Erubini Body Kit for sale
    Quote Originally Posted by bronxbombr
    i agree, could be air in the lines..
    2009 Mitsubishi Lancer Ralliart
    JDM 5 SPEED 4G64
    TO GET TO A MAN'S HEART....IS THROUGH 4G64 egh and may be through 4B11T
    New Member kungfuwaffles's Avatar
    07-16-2006
    Virginia Beach, VA
    97
    do your fans turn on....may want to check and see if your fans are in working order....because it sounds like the fan clutch is starting to go bad..causing the increase in temp....had that problem with a dsm before..notorious for it..cost you about $120 or so
    01-19-2007
    Clifton, NJ
    3,471
    I agree sounds like a fan problem...
    03-01-2005
    Houston, Tx
    1,049
    yea.... i had the same problem.... when ur gauges starts to go up.... turn ur heat on.... the gauge should go down.... Check the fluid.... the fan... and it may be ur thermostat
    fluid hasnt been changed in like 3 years. Is it difficult to replace the thermostat? im not to mechanically gifted.
    thanks for all your responses, really appreciate it.
    Start with the easiest first, replace the radiator cap.
    yea i'm having that exact problem.... what i noticed is it's rush caked up from just having water (i looked under my radiator cap) get your coolant flushed that's what i'm doing this week. It will most likely solve the problem unless it's gotten alot worse. But my car goes about 3/4 after driving but then goes back to normal. It's weird that's why i'm almost certain theres just caked up rust.
    i think my fan craped out. I had the car in park, turn the heat on full blast, and there was cool air coming out.
    Then i looke under the hood, and the fan wasnt spinning.
    Do you guys its the fan, or the clutch/switch.
    If I can get a used fan somwhere, is it difficult to replace it?
    Thanks
    Quote Originally Posted by willieB
    Thanks
    If you had the car in park, and the temp gauge was reading normal or above, and you turned the heat on full and only got cool air, sounds like your thermostat is sticking closed.
    is replacing thermostat relatevily easy task to do?
    i just did it....it isn't bad at all... u gotta take your battery out and ur battery tray...it's right on the rightside...follow the tubing to the side u'll def. see it... it's like 2 bolts it can be replaced within 15 minutes
