I dont have the wiring diagrams on this computer, I can find it tomorrow.....
Does anyone know where the location of the tachometer wire is at? i'm installing a remote start, i have a guide and it says it's in a connector next to the fuse box onder hood...can anyone help.
4G64/63T
AEM EMS
Nevermind. I dont have anything showing where it is under the hood, I only have here to get it from the ECU connectors. From the ECU connectors it is pin# 43 which should be a white wire with a red stripe. That is the ECU RPM signal output.
If your looking at the connectors while they are plugged into the ECU and ECU right side up, its the 2nd connector plug from the left, top row, 3rd wire in from the left.
Hope this helps.
4G64/63T
AEM EMS
