since the evo rotor mounts on the galant bearing, the front offset and backspacing should be the same...(i hope)
on the rear
this is the complete assy from aN 8 g
so like i said im pretty sure i cant just remove the cylinder and rear drum plate and put the evo rotor in there my offset is gonna be huge
https://www.thegalantcenter.org/view...onversion+swap
is this topic supposed to be the how to ?
didnt help at all...
anyways the rear disc assembly i might need , the caliper brackets too
il get some ss brake lines for better pressure , and evo pads
