interesting!! post picz when done!!
I again can’t mention enough on Stewi sending me to PLX devices for there gauges. :smt023
I picked up the new DM-100 Digital/Programmable display module and controller. Also got the AIT and EGT sensor modules and will be using the DM-100 to view them both (can view up to 4 sensor modules at a time).
The greatest part about PLX’s advanced technology is the price, which is absolutely outstanding. The DM-100 is $210, while the sensor modules SM-EGT and SM-AIT both run for $125, including sensors (they are $30-40 cheaper if you have the sensors already).
They all have analog outputs so you can completely replace factory units if you choose.
I still plan on getting the Boost/Vacuum, Oil Pressure (w/2 inputs), Fluid Temperature (w/2 inputs), and OBD-II monitor. I should have them all by the end of the month. :D
Oh yea, and got an Aeromotive FPR installed! Much easer to tune in boost...
http://www.plxdevices.com/
Check PLX out if you guys got some time…
DM-100
SM-AIT
SM-EGT
Looking good man, let me know when you want to get together so I can check out the new goodies.
222whp/250wtq
