yes you can use the 2G stuff but only the FWD (95-99 GST)
clutch is the same and flywheel is the same. you can even use the eclipse tranny if you wanted too
tranny
mounts
shifter assembly
shifter cables
pedals
master cylinder
slave cylinder
there is a tutorial in the 7G section at the top as a sticky
