Thread: TCU Problem????...please read through
Showing results 1 to 5 of 5
    suchluke
    Its 1998 Galant with auto trans. The car started acting wierd this morning. When coming to the stop there is a big slam when downshifting from 2 to 1. There was also a problem when cruising on 2 and when hit on accelerator the tranny would slam to 1st. The rest of the gears works smooth. There is no problem with over drive. The car downshifts from od when going down hill, but after reading forums it seems normal (engine breaking). Does anyone had similar problem? I was thinking TCU, but I am not sure. Any help/comments would be greatly appriciated.
    Second question. I am sure it has nothing to do with problem above. This was since we got the car. The tranny shifter button on top does not work. I can move the shifter without applying the brake or pressing the button on top. The side over drive button works fine. Any ideas?
    Tranny isn't easy to diagnose, though It doesn't sound like the TCU usually that involves electrical malfunctions and CEL comes on.
    Sounds more like something mechanical going on inside the trans is starting/gone to crap, if I had to begin to guess. First start by checking the basics like thre fluid and its condition. Then check and see if the TCU has any codes. I would also check the ECU while your at it.
    07-20-2003
    Orlando, FL
    3,169
    Sounds more mechanical than electrical. What you are describing as the issue may be a bad torque converter possiblly.
    Quote Originally Posted by 4-G-rim View Post
    First thing that ran through my mind after i read it.
    1996 galant s
    Member
    08-08-2007
    Minneapolis, MN 55407
    151
    Take your car in for a vehicle inspection they would do it for free at autoshops.
