driving around for 2 and a half hours isnt any kind of risk at all. i have made a 3 hour drive nonstop plenty of times and have never had any problems
Wow your an idiot, you shouldn't even own a galant or any car in that matter, and you need to go back through drivers ed
2000 Galant ES 2.4L
...pain is temporary, pride is forever...
because the factory hood lock sometimes wont hold at 100+mph and just hood pins plus the hood lever which btw is about 1-2 inches of metal isnt going to hold against high wind speed + 40-50 mph, also you are hurting your areodynamics by doing this, just get the CF hood and make covers for the vents for when you arnt using them
i'll get a whole list of parts for u dude no worries
oh boo whooo, i ran my car for 6 hours coming back from toronto, and guess what, it doesn't over heat, not to mention STL and chicago are 2.5 horus away from me and i have gone there tons of times, and same thing, never over heats.
i just really think you forgot to check your ego at the door or something
Its a road hazard! Did'nt they teach you road hazards
2000 Galant ES 2.4L
Bro my job is 7 days a week, meaning its running 'continiously' for 2.5 - 3 hours "daily" (5 hours every sunday) . Over a period of time im pretty sure it needs some precautions.
Speaking of precautions i think something is wrong with my springs or struts, there starting to squeak over little bumps, and i hear a lot of Clunking noises when i go over main street potholes and bumps.
i think its due to the continious driving on peoples driveways, can anyone refer to me to durable struts and spring preferably for a Job like this.
look into KYB GR2 shocks or AGX. the agx are adjustable while the gr2 are not. i dont think ur car is going to over heat honestly, i drive my car for 1:30-2 hours and im turbo'd which is wayyy more heat in the engine bay then you and i have no issues.
00 Galant ES Turbo/5-Speed
13 GTR
But do the noises i described show signs of damaged spings or struts?
i would get Tein S tech or progress if you want a drop (both give different amount of drop) these will give you a better look and handling if you dont want a drop just go with the OEM ones. I would try driving ur route with ur hood fully closed and watch your engine temp. gauge, if it does overheat something has to be broke. Its a newer car and they are made to withstand daily/ long road driving, so there should be no problems with overheating. If you really want that then buy the cf hood like they said it will suck in more air directly to your intake and engine and is lighter then the stock hood. you will improve your aerodynamics and be getting more air flow also it will drop the weight of your car.
2000 Galant ES 2.4L
yea it does, my honda accord does the same thing and its needs springs and struts, but in worst case it could be ur ball joints, or tierod, it all depends
2000 Galant ES 2.4L
it's probably the driver
well all the responses you are getting about you driving with your hood open are because it is just about the WORST idea we've ever heard. seriously. nobody should ever do this on purpose. your car will NOT overheat from driving... and if it does, you have cooling system issues that cracking your hood and letting air in will NOT fix. i don't know how to explain this more simply. it is just USELESS. i couldn't even get to your other questions since your idea that driving around with your hood cracked open was so ridiculous allready.
then instead of taking GOOD advice, you defend your misguided position... and who are you to defend anything to us, whom you are asking for advice from? what have you ever done on your car that merrits you possesing any knowledge about it or even cars in general? so you are safe driving around with your hood cracked because you said so? sorry, i don't recognize your expertise. you trying to inform us on how the intake and cooling systems function and trying to look informed only makes you appear more and more ignorant. if you are going to ask such elementary questions then LISTEN and LEARN since it's abundantly obvious you do not know what you are talking about.
theres is NO BENEFIT from driving around with your hood "cracked" open.
since there is no benefit, do you even need to take the risk of it flying open?
keep your hood CLOSED COMPLETELY when driving.
just take it to a shop. the reason 99.99% of owners let a shop do this is becasue shops do a much better job than a novice (and to most of us, it's not worth our time to DIY).
I drive with my trunk open for downforce.
Love,
Matt
