Thread: Baby G ~ 2000 Galant ES I4
Page 61 of 70 FirstFirst ... 1151575859606162636465 ... LastLast
Showing results 1,201 to 1,220 of 1389
  1. #1201
    Are you using a walbro 255? If so I'd be more than willing to bet you were at the limits there of. 10.7 AFR's with that kind of power on stock fuel lines, 255 would be about capped out.
  2. #1202
    I'm on a walbro 450 with a -6 feed and a -6 return up to the firewall. Then stock return to the tank.
    Jigz-TGCIL Sosick Motorsports
  3. #1203
    And thanks for the words of encouragement fellas. I've got a lot of work to do but unfortunately with the holidays coming up babyg may need to be pushed to the back burner for a while.
  4. #1204
    I hear ya there
  5. #1205
    Bryant, I am using 1000cc RC injectors
  6. #1206
    Yeah man it's the nature of the beast. You mod cars and you risk this. Look at it as a blessing. That blown motor could have saved your life. Who knows. Somethings are out of your control. I personally believe everything happens for a reason. Some of those reasons we never get to see or understand in our lifetime but there was a purpose. So there might be a reason why you have to put it off until later.
    The "Tumbler" Is Here
    3xxWHP/3xxWTQ [Current]
  7. #1207
    Yeah everything happens for a reason. I'm just trying to stay positive About it you know. I'm pretty sure I can replace just that piston and clean up the cylinder wall with muriatic acid to get the melted aluminum off the top of the cylinder. The cross hatch is still in good condition but I figure I would run a ball hone in it to freshen it up so the new rings in that cylinder break in properly. I have to call wiseco tomorrow and see if a replacement piston is something I can order.
  8. #1208
    12-13-2010
    Brooklyn, Maryland
    4,643
    Damn that sucks. Great numbers though, incredible numbers!
    -Greg
  9. #1209
    TGC Regular boosting90's Avatar
    05-14-2014
    Central Florida
    426
    Uuufffff well tht sucks cojones..... but like some guys said those numbers.... u know what to expect when u come back. Nice numbers. Push g to the side and enjoy holidays. U will come stronger.
  10. #1210
    Will you have BabyG for out get together?
  11. #1211
    Dave, unfortunately I will not. But I will have my stanced Lancer so it will still be an all mitsu outing!
  12. #1212
  13. #1213
    Got the injectors flow tested, and they all checked out good. I am scratching my head for sure. Ordered a piston and getting the head sent out to get new valves on cylinder 4 and cleaned up, decked, etc.
    Only thing that I believe may have happened is that the Piston developed a hairline crack that went unnoticed when the pistons was hitting the bottom of the cylinder head due to the wrong head gasket and at 26psi it broke off and killed the plug. Though this may be far fetched, idk what else would cause this catastrophic damage.
  14. #1214
    What head gasket are you using??
    Sent from my Galaxy S4
    '91 Kawasaki ZX7 (SOLD)
    '95 Kawasaki ZX9R
  15. #1215
    I was using the Cometic recently but the time before it was the OEM 4g64 headgasket. The OEM gasket caused the tops of the pistons to hit the bottom of the head. I mentioned it a couple pages back from last time.
  16. #1216
    The cometic is three times the thickness of the stock head gasket so I highly doubt it that the head gasket was the issue.
    '95 Kawasaki ZX9R
  17. #1217
    I WAS SAYING that the pistons may have cracked from before and we didnt see it putting it back together. I didnt say the head gasket was the issue THIS TIME, I was saying the old head gasket that caused the pistons to hit the bottom of the head may have led to the piston cracking and finally broke off at 26 psi of boost. Like I said far fetched but the injectors are good so I am scratching my head here.
  18. #1218
    U can chill out. I just misread your post. No need for any of this.
    '95 Kawasaki ZX9R
  19. #1219
    Did u check the rod bolts and made sure they didn't come loose which allowed the piston to contact the head??
    '95 Kawasaki ZX9R
  20. #1220
    You would detect knock with that I'm quite positive
    Sent from my DROID RAZR using Tapatalk
