Thread: XENON HID CONVERSION
Page 1 of 2 12 LastLast
Showing results 1 to 20 of 22
    stm
    Hi, I’m new in here and I need some advice
    I have Mitsubishi Galant 2002 and I tried to upgrade my headlight bulbs
    And it didn’t worked out for me that well
    Did any of you tried to convert to SUPER HID 6000K CONVERSION KIT by SUPER VISION :?: :?: :?:
    Let me know what do you guys think about it
    STM
    Tazz2000
    I used Eagleye's from Midnight Moose
    Got confused, figured it out, then found the instructions in English WITH picrures. I felt like a dumbass. But that's ok.
    MY HEADLIGHTS LOOK BETTER THAN YOURS
    stm
    HID
    I found HID KIT for $ 360 can somebody tell me if it's worth it
    TGC Regular
    08-01-2002
    S. CAROLINA/GEORGIA
    758
    Where did you find that kit? I'd say that is probably worth it, but usually with HID kits like that, it will only be one beam pattern. So you will lose your ability to switch to "high" beams. And what is reportly happening to others who go with this kit, is that they continuously get "flashed" by oncoming cars to dim their lights, since the HIDs are so bright. Personally, I'm waiting for an affordable Hi/Lo beam HID conversion kit. There are a couple of "dual" beam HID conversions kit already out, but they are still a bit too pricey for me. I rather spend that kind of money on a bodykit before a lighting system.
    stm
    I jus got it for $338 from ebay :?
    meanrick1969
    How good is that kit, im thinking of buying it also?
    stm
    I’m still waiting for it,
    It’s suppose to be delivered on Tuesday
    :thumbsup:
    Nick VR4
    This might be of intrest
    based in OAKLAND ....CAL
    http://www.eautoworks.com/html/lbu-Light~b...ight~System.htm
    Senior TGC Member
    07-31-2002
    Sugar Land, Texas, United States
    2,175
    I don't like the look of that Super Vision kit...it looks like they colored the bulb.
    Yeah, you guys gotta becareful with generic brands like that....Alot of them just breaks in the first few months of use......
    Although reputable brand names like Phillips, Hella......etc are more expensive, they are definitely more reliable....
    2001 Galant ES I4
    Injen RD CAI
    Kamikaze Headers
    Brospeed Prosport Muffler
    Brembo X-drilled/Slotted Rotors
    Progress Springs
    KYB AGX Adjustables
    Racing X Headlights
    Smoked Tails
    Custom Grill
    Titanium Limo Tint
    MOMO Shift Knob
    Tenzo R Mean-6 18"
    JBL 600.1
    2 JL 12W3 D4 in topfire custom box
    My ride: http://photos.yahoo.com/nrg_neo
    stm
    Check this out
    what you guys think about this one
    8)
    ThaKiDThaTWinS
    Sup guys...been a while since my last post...i prolly been totally forgotten buti got a RSX so thats y i been MIA. But i got a connection for some Hella H.I.D.'z i already got some on my RSX. i found some H.I.D. adapter that fit in perfectly...but i cant find one for a galant...do they even make them? If u got Hids how did u put them in with out melting and cutting etc.
    stm
    Finally I got my HID installed
    Looks good and bright 8)
    But here comes another question can I remove protectors from hid bulbs
    Will it be better or worth :?:?:?:?:?
    Tazz2000
    Remove the projectors from the HID bulb? What are you talking about?
  15. #15
    stm
    there is a cover on H4
  16. #16
    sum1 correct me if im wrong but don't u need that to switch between high and low?
  17. #17
    <div class='quotetop'>QUOTE(PinoyESV6)</div><div class='quotemain'>sum1 correct me if im wrong but don't u need that to switch between high and low?</div>
    let see if i understand your question, with H4 bulb the high and low beam are together,,,
    AkA K h O p A r I.
    I Am back BitcheZzZ
  18. #18
    <div class='quotetop'>QUOTE(K h O p A r I)</div><div class='quotemain'><div class='quotetop'>QUOTE(PinoyESV6)</div><div class='quotemain'>sum1 correct me if im wrong but don't u need that to switch between high and low?</div>
    let see if i understand your question, with H4 bulb the high and low beam are together,,,</div>
    yea, thats how they've always been. your stock headlights are like that. but some HID like bgr's are only low. with the dual beam HID H4's i believe the relector moves to switch from high and low
  19. #19
    <div class='quotetop'>QUOTE(PinoyESV6)</div><div class='quotemain'><div class='quotetop'>QUOTE(K h O p A r I)</div><div class='quotemain'><div class='quotetop'>QUOTE(PinoyESV6)</div><div class='quotemain'>sum1 correct me if im wrong but don't u need that to switch between high and low?</div>
    yea, thats how they've always been. your stock headlights are like that. but some HID like bgr's are only low. with the dual beam HID H4's i believe the relector moves to switch from high and low</div>
    yea, than he sould just get the H4,,, i dont know why people want get HID,, like the whole kit,, whats the diffrent
    AkA K h O p A r I.
    I Am back BitcheZzZ
  20. #20
    stm
    on my HID i have low beam only
