you must have to trim it down your self a little bit or somthing
Very nice, thanks for the pics guys, just bought one now
i had to trim by the airbag cause of a crack i had there you can tell were cause its not even with the airbag
I have three major cracks and a large hole in my dash that have all developed over the last several months. I guess that I should piece the dash together the best that I can and then put the overlay on for appearance purposes and paint.
I had pieces just about falling off the dash, but if you're willing to do the work, you can remove it completely (the vents should hold it together while you take it out), and use plastic weld epoxy to put it all back together. You might also be able to use the dash mat as a form to glue everything to if it's real bad. While the dash is out, you can paint it, too.
2000 Mitsubishi Galant (totalled by semi, RIP)
2000 Mitsubishi Galant - Bought off Craigslist, received organ donation from last one:
- Engine/5spd trans/interior/suspension/brakes/etc. all moved from old car
- 5spd | Outlander IM | StopTech BBK | Defi VSD-X HUD
i wish they had one with a hole cut for the center channel speaker
on mine theres an imprint of the center speaker so im assuming you cut it
Sweet, my dash is cracked in two spots, ill be ordering one of these very soon! thanks guys
Well I've been digging threw the forum n found thread. Well upon getting in my car today I just so happened to notice a crack in my dash coming from the defrost vent down. I read in eastwood magazine that theres dash repair kits. Would any of you recommend this or do the dash overlay. N do they still have it? N are there any other colors then black?
just get the dash overlay. it comes in different colors or you can just paint it to the color you desire.
here is a pic of mine. it is directly from COVERLAY (http://www.coverlaymfg.com/store.php...-galant-24-903). additionally i painted the forward vents and the airbag cover with black vinyl dye to match.
What about this???
http://www.eastwood.com/vinyl-and-da...ir-system.html
I spent $150 on my plastic dash cover and $5 on paint and it looks GREAT!! A new dash costs over $700!!
Just be sure to put the adhesive on any loose areas of the old dash so it will not vibrate underneath. Also weight it down while the adhesive sets. I cast bullets for reloading and have a lot of 1 and 2 lb lead ingots which spread around the dash and worked great. Just make sure to use SEMI-GLOSS paint. I wasn't thinking and used gloss and it glares on the windshield, I will repaint it with clear semi-gloss. It was pretty easy to paint it in place.
2002 ES, V6, 140K
looks good. i used like 10 phone books to weigh it down overnight while the adhesive was setting/drying. i also wedged folded corrugated cardboard between the windshield and the dash to give is space and to firmly hold the leading edge against the dash underneath until it dried.
