Thread: **official aggressive wheel thread**
Page 20 of 21 FirstFirst ... 10161718192021 LastLast
Showing results 381 to 400 of 410
  1. #381
    Quote Originally Posted by 99galantES View Post
    Mine are like that because its a 3pc wheel
    Exactly. Same here
    -Danny
    Quote Originally Posted by deeznutz View Post
    Ally and her whip a day helps keep the drama away!
  2. #382
    05-02-2008
    Hacienda Heights, CA
    3,014
    I think they do it that way since they are reverse mount. I could be wrong though.
  3. #383
    No more max wheels ? What are you rockin now?
    Can you size down your sig please? Thanks, Admin :)
  4. #384
    hellaflushgalant
    Hi i have a 1999 Mitsubishi Galant and i need to get at least 3-5 negative camber in the rear so my wheels don't rub i have tried everything and nothing works my wheels are 18x9
  5. #385
    What are your wheels offset?
    What is your tire size?
    Has the can been aligned since it was lowered?
    Have you rolled the rear fenders since installing the wheels?
  6. #386
    hellaflushgalant
    The tire size is 225 45 r18, the offset is 28mm, the ride hight is stock and yes they are rolled. I went to a performance shop and they told me i needed to have rear camber and i don't know where i can buy a kit or the parts to make it have camber i haven't found anything
    Any help is greatly Appreciated, Thanks
  7. #387
  8. #388
    Your tires are also too tall.
  9. #389
    Theres nothing aggressive about +28 18's wrapped in the wrong tire size on stock ride height.
  10. #390
    hellaflushgalant
    So where can I rear Camber kit for the 99 Galant any links or brands will help
    Thanks
  11. #391
    The rear will camber in when lowered.
    You should do that.
    9j +28 has to look super dorky at stock height.
    And get the right size tires.
    And just search 'camber kit' on here.
  12. #392
    Ingalls makes a good kit. Go on ebay and search for it.
    Lowering the car to a flush stance is at least a 2.5in drop, with Tein springs lowering the rear 1.3 inches my alignment spec sheet came in at about 2.9 to 3.1 negative in the rear with no camber kits. Simply lowering the thing with coil overs will probably get you where you need to be.
  13. #393
    hellaflushgalant
    Thanks i appreciate all of your Help!
  14. #394
    17x9 +35 up front +27 effectively in the rear. Needed an 8mm slip on in the rear because the tire rubbed the arm that goes from the hub to the uppercontrol arm. Going to put some extended lug studs on it probably next week.
    The tires is a 255/40/17 Hankook RS3. -3 camber in the rear and about 0 up front. Still need to get her on an alignment rack
    BTW, this bitch is running and driving and she is trouble.
    Jigz-TGCIL Sosick Motorsports
  15. #395
    255s you are a crazy man!!
  16. #396
    if i could put bigger tires on I would this thing needs it. a little bit of boost and its instant tire smoke.
  17. #397
    I'm lovin' the new setup Jigz!
  18. #398
    how are you liking the rs3's? im looking for some tires for road course fun this season. I was debating between the rs3's or the Potenza s-04 pole position.
  19. #399
    Thanks Matt!!
    Drone, on other cars theyre awesome. I havent had enough time with them on BabyG just yet but I have high hopes
  20. #400
    10-24-2003
    1,432
    255's are where its at! I'm hoping to figure out how to fit a 275-295 front for some epic corner carving!
    www.gooichimotorsports.com
