well it's easy to see if the timing belt broke on the left side of the engine if your looking at it from the front there is a plastic belt cover, just pry it out abit and see if the belt is there, try turning it JUST A WEEE BIT, if you can turn it at all then your belt is broke, if not then your good, if it overheated and it won't start at all, there's no telling what could have happened start with any codes the ecu is throwing and go from there.
"EDIT" i just noticed you have a v6 so you "kinda" have 2 timing belts so you'll have to check each head individualy, but like i said just try to turn a LITTLE BIT you don't want to fuck up your timing, if it turn's easly then your belt is broke
