Showing results 1 to 10 of 10
Thread: transmission drain plug?
    could you guys tell me where is the transmission drain plog on a 01 Galant?
    I've spent the last 20 minutes but still couldn't find it.
    thanks
    Laz
    center of the bottom most likely
    center?
    How big is it? All I see is two probably size 7 bolt. Unscrewed one of them but
    that's just a long screw. I was assuming the drain plug is much bigger.
    I still can't see it. I say a blach vertical pan on the front of the transmission but those are really corroded bolts. Looks like never been removed.
    I may post a video see if you guys can spot it
    It should be a flat looking screw head near your transmission pan, about 15/16 size socket to unscrew it.
    pictures
    I took a few pictures, let me know if you see anyhting like that.
    http://s602.photobucket.com/albums/t...albumview=grid
    go look at the manual to auto conversion tutorial. There's a picture of the trans with the fluid being drained out of it.
    Jigz-TGCIL Sosick Motorsports
    #BabyG- 4G64/G4JS, Precision 5858, Quaiffe LSD - 443 whp/417wtq @ 26psi 362/325 @ 17.1psi on 93
    #Tswizzle- 6G72 5-speed
    #Eve- 05 EVO8, HKS272, Bolt-ons, 309whp 302wtq @ 25psi
    manual
    I don't have the manual that's why I'm asking dumb questions
    found it?
    I have removed the driver side wheel and behind the plastic cover on the left side of the tranny there is a flat, huge bolt. rusty like hell
    Quote Originally Posted by laszlopmagyar View Post
    I know you don't. I meant in the tutorial section there is a Automatic transmission to Manual transmission thread that shows where the plug is.
    see the hole where the trainsmission oil is coming out of? thats the bolt you must take out
