have them installed on my 9g GTS. Here's the link if you want to see pics. It's actually 1.750 inch drop F&R and it's made in Japan
http://www.vhoist.com/ride/101222
does anyone have these on there 9g i found some orange ones that would go with my orange RA they cost 108$ and lower the car 2"F & 1.9"R
I'm running them too good sprigs, the ride is not bad at all, mine are all seated in now the ride height said 2.0 but I'm at 1.8, and they do make the car look and handle better, if you do a MM switch and front strut bar you will feel the propose of drop springs. and for good measure check your sway bar rods you may want to replace them.
Your signature is against the rules too - Prophet
