Thread: Rear disc swap
Showing results 1 to 5 of 5
    Rear disc swap
    Does anyone know what the part number is for the v6 E-brake cable? I want to do the swap and think that instead of modifying the backing it would be easier to but the cables.
    Also do yall know if this is the right parts to buy http://www.rockauto.com/catalog/rafr...1356689k925312
    Lamar Gilmore
    TGC Regular Boosted's Avatar
    12-03-2008
    Fayetteville, NC
    575
    Yes, that is the correct part.
    08-04-2003
    NY
    4,344
    You just need to make sure you have rear's from a GTZ or Eclipse GT. If you have the older setup like me from a 2g, the V6 e-brake cable is still different.
    99' Galant ES
    4G64/63T
    AEM EMS
    cool thanks for the help
    Lamar Gilmore
    The part numbers that I bought are as follows -
    Backing plates - MB950207 and MB950208
    Shoe Set - MB950211
    E Brake Cables - MR334357 and MR334358
    E Brake Cable nut (needed to attach the eBrake cable to the backing plate) MB288653 (Qty. 2)
    I also changed the proportioning valve. I'm not sure if you plan on doing that. Let me know if you need the part number.
