bad plugs?
hi people, im having a problem whit my G, when it go up to 3500 RPM, the car loose power :S
anyone know what can be?
__________________
-Mitsubishi Galant (4G64 SOHC) ES 1996, 5spd Swapped.
-Mitsubishi Galant LS 1994 a/t [ SOLD ]
bad compresion??? Low oil presure... there are a millions answers to what you said... We need you to be a little more specific...
in my libero i had the same problem, I blamed the distributor but it turned out to be as simple as changing the plugs.
it runs fine until you put your foot down then it chokes does that sound about right?
timing? jump a tooth sound like
http://www.gasketer.ecrater.com/
get you OEM parts with low price
here is a video, in 2nd grear at 0:08... in 1st grear no because the horn ¬¬!
http://www.youtube.com/watch?v=nBYNdusYBTY
__________________
change the plugs its gonna cost you hardly anything and if its not plugs causing it doesnt matter because there not expensive.
yes,
__________________
i put a new distributor, and now runs "good" but sometimes keep makin it at 3500rpm
__________________
