from what ive read in the past....old style fogs clip right in if you modify the stock fog harness;new style what I did is you can clip the bulbs from the bulb base attach spade connectors call it a day
http://www.galanttuners.com/kb.php?a=57
^^you can do it this way or splice it to your parking light.
the fogs just cut the USDM harness and splice it with the jdm fogs.
http://vids.myspace.com/index.cfm?fu...ideoid=2799274
A filipino's number one dream is to own a car before anything else. In the philippines, most private car owners consider their vehicles as an extension of their home but with one differrence: a home is where his wife cooks while a car is where his girlfriend builds a fire. Hmmm...
the "new style" (JDM VR4/VIENTO 1998+) fog lights are fog and turning flood (not quad fog, or fog and signal, or fog and corner marker, as many people wire them as). you can wire them any way you'd like but ASTIG worked out the wiring w/ capacitors/relays for the outside pair to function as intended, as turning floods (they steadily illuminate the side you signal to so you can see into the turn). search for ASTIG's workaround.
actually here it is:
thats the thread he posted...which is way more in depth...for most those 2 pics look like electrical jargon
