Thread: Post What You Did To Your Car or Bought Today!
Page 406 of 538 FirstFirst ... 306356396402403404405406407408409410416456506 ... LastLast
Showing results 8,101 to 8,120 of 10744
  1. #8101
    Most likely they will be the same part numbers. For example the battery looks like a group 86 which the galants take them already.
  2. #8102
    05-03-2009
    Aguadilla, Puerto Rico
    1,465
    Got my exhaust manifold chrome ceramic coated and installed it, turbo blanket is on, installed a catch can and mounted my mbc, still need to run the lines for the mbc so don't worry about the wastegate not connected to a boost source.
    Tomorrow I'll be installing my new valve cover ;)
    4g64T 5spd
  3. #8103
    Not mine. But not telling who it is for.
    Sent from my Galaxy S4
    '91 Kawasaki ZX7 (SOLD)
    '95 Kawasaki ZX9R
  4. #8104
    12-13-2010
    Brooklyn, Maryland
    4,643
    ^^Looks damn good!
    -Greg
  5. #8105
    05-03-2009
    1,465
    Now the engine bay and turbo build are done I just need to get the tune finished, stock motor 4g64 turbo:
    4g64T 5spd
  6. #8106
    12-13-2010
    Brooklyn, Maryland
    4,643
    ^^Nice COP setup!
    -Greg
  7. #8107
    TGC Regular djhah's Avatar
    03-15-2010
    nashville, tn
    505
    looks nice man!
  8. #8108
    Yeah that COP does look top notch Omega and so does the valve cover spdracr
  9. #8109
    Old coilovers were rusted and seized.
    Took them apart, took me 3 hours with pb blaster, chisel, hammer and a torch. The lock rings got chewed up but they're still functional. Stripped all the springs and front sleeves and coated them. And used a wire wheel on a bench grinder to get all the baked rust off the threads. Used plenty of anti seize.
    Those are going on the daily soon.
    '95 Kawasaki ZX9R
  10. #8110
    12-13-2010
    Brooklyn, Maryland
    4,643
    Anti-seize is man's best friend lol!
    -Greg
  11. #8111
    03-15-2010
    nashville, tn
    505
    you got that right, greg! took the words right out of my mouth.
  12. #8112
    07-02-2011
    South Florida, by the beach
    1,076
    My babies
    Put new spark plugs in the Galant, I have the infamous p0300, I think mine is my 02 sensors still, will order new ones, I only have 2 bungs with my exhaust so I spliced the left bank together and the right bank together, this time I'm going to try to splice both uppers together and bother lowers together, I'll see if that helps.
    I also undid the wire loom and tucked the MDP wires since the 6g74 IM makes the stock wires stretch across the 74 IM.
    01 Galant ES V6 MT (sold)
    00 Eclipse RS MT
  13. #8113
    Hey Spdrcr....I also have megans coilovers and will be installing them within this month....I plan to go as low as I can go to eliminate the wheel gap I dont want them to tuck does any one know the camber plate should be centered?
    wise up or stand down
  14. #8114
    Quote Originally Posted by jamesgalant View Post
    My camber plates are still centered and I have a small gap between the fender and tire. You will see as you do it.
    '95 Kawasaki ZX9R
  15. #8115
    Quote Originally Posted by Black8GV6 View Post
    My babies
    Is that the cat warm-up code? I forgot the number but i think thats the code I had. I still have a light on now but just been riding with it. I'll have to get it scanned again at somepoint and figure a solution. Same shop told me recently, seems like my headgasket is tryna give out on me, but to let it go for the moment. Was leaking a small amount of oil, and they also said coolant. But all I ever see in the driveway is oil, but none lately for the past 3 days
  16. #8116
    07-02-2011
    1,076
    P0300 could be 1 of several things, I got my 2 new 02 sensors today, I work until sunday night so monday I'll extend and put in the 02 sensors and hopefully the P0300 code goes away, I'll let you know if it fixes it.
    00 Eclipse RS MT
  17. #8117
    02-08-2012
    Hackensack NJ
    1,146
    I'm not sure but, I vaguely remember when I had that code and it was for the either the 02 sensor or the spark plugs but I'm not sure which was which, but I think it was the 02
  18. #8118
    11-18-2009
    Buffalo, NY
    1,758
    P0300 is a random misfire which in his case is probably caused by a rich condition.
    Sent from my iPhone 5 using Tapatalk Pro.
    - Chris -
    DRL Delete
  19. #8119
    My p0300 was caused by a coil and bad ground straps.
    There really isn't one definite fix for it. It's such a vague code that has lots of different ways to fix it.
    '95 Kawasaki ZX9R
  20. #8120
    03-16-2010
    Maplewood, NJ
    1,290
    Got a LED package from my cousin for xmas. I installed them on Monday but I only got to post the pics today. No pics of how bright the entire cabin is. Its really bright. The thing I love about these LEDs is that some of them are adjustable.
    13 Honda Accord EX 6MT
