Thread: Post What You Did To Your Car or Bought Today!
Page 476 of 538 FirstFirst ... 376426466472473474475476477478479480486526 ... LastLast
Showing results 9,501 to 9,520 of 10744
  1. #9501
    Looks incredibly clean!
  2. #9502
    03-12-2012
    Manvel Texas
    1,171
    Agree.
  3. #9503
    Finally got around to installing LED turn signals today since the resistors came in late yesterday afternoon.
  4. #9504
    03-12-2012
    Manvel Texas
    1,171
    Not the best choice of connector, I would of cut , solder, heat shrink. But I like the lights.
  5. #9505
    My damn soldering iron burnt up on my last project, otherwise I would have. I guess I will have to go invest in another one.
  6. #9506
    Cut, strip, twist together, tape up..."western union" technique...way better than those connectors...but hey, if it works =D (for now)
    Fun fact of the day:
    The NASA spec way to splice wires is to strip the ends, solder each wire individually, then hold them together side by side WITHOUT twisting them, then melt the solder together. That creates a better flowing and stronger bond than a single run of wire!
    It is also a massive pain in the dick and uses a crap load of time
  7. #9507
    lol if these connectors fail (wouldn't be surprised) I will hopefully have a soldering iron by then.
  8. #9508
    At least you are realistic! So many people don't fit that trait
  9. #9509
    Quote Originally Posted by demond0d5 View Post
    SMH. That is the ONLY correct way to solder. Its called "tinning".
  10. #9510
    It wouldn't be the first time I had to redo something little like that cause I screwed up the first time. At least by the second time I know what I'm doing lol
  11. #9511
    "tinning" is simply coating the material...not actually joining it. Joining it is called soldering. Hence why you "tin" the soldering iron prior to working or "tin" the wires before joining. Tinning allows the heat to transfer easier from the iron as the material is already at a melting temperature and has a lower specific heat index than the material (copper, silver, etc) being soldered together.
    The more common method of soldering is to overlap the wires parallel to each other, twist them together, and then solder. This is much easier because you only have to hold 3 things at once, the iron, the solder, and the conjoined wires (if unsupported), as opposed to the other method requiring you to hold both wires next to each other, the iron, and the solder (if you choose to strengthen the bond further)
  12. #9512
    08-26-2007
    L.I.N.Y./ Rockville MD
    1,148
    I wish my car was worthy of some aerospace methods
  13. #9513
    Today should be a good day...unless I find out I have to replace a fuck ton of other suspension parts
  14. #9514
    Quote Originally Posted by xd_01 View Post
    If you have AN fittings, you're using aerospace methods. I could go on and on lol You're GOOD!
  15. #9515
    03-12-2012
    Manvel Texas
    1,171
    Quote Originally Posted by juicejax View Post
    Theres always more to replace and improvements. Lol. Have fun
  16. #9516
    Most likely that will be the case.
    Ball joints and sway links. Maybe control arm bushings. Usually the case with a 12+ year old car.
  17. #9517
    Could I just get the springs and struts installed...and do the other parts the next day...I'm dropping my car off at a shop in the morning... $300 including alignment...I know I'll need the camber kit for the rear as well
  18. #9518
    You can go back to that stuff later, im just saying, most 8Gs on the road, they need that sort of work done, most people dont bother since the car can still get from A to B.
  19. #9519
    Oh I know all this lol. I guess smh didnt come across right. Nodding my head agreeing with you was what I was trying to do. Eh oh well
    Sent from my DROID RAZR using Tapatalk
  20. #9520
    I want your head lights technOnut xD
