Thread: Post What You Did To Your Car or Bought Today!
Page 514 of 538 FirstFirst ... 14414464504510511512513514515516517518524 ... LastLast
Showing results 10,261 to 10,280 of 10744
  1. #10261
    Quote Originally Posted by Techn0Nut1996 View Post
    Check Engine light came on... dammit. Nothing looked/sounded/felt wrong tho, I'll take it to the shop this weekend.
    I'm gonna say its emissions related if you don't feel a change in the car.
  2. #10262
    It has always sort of smelled like it's had an exhaust leak.. Not inside the car but when you first start it up and get outside it does smell rather smelly.That would make sense actually. How does one investigate this issue?
    1991 Jeep Comanche (SOLD)
    2002 Honda Accord EX (DAILY)
    1998 Eclipse GST (PROJECT)
  3. #10263
    Code first
  4. #10264
    Fair enough
  5. #10265
    These arrived yesterday
    '91 Kawasaki ZX7 (SOLD)
    '95 Kawasaki ZX9R
  6. #10266
    These are vied yesterday
    I want to see these installed!!!
  7. #10267
    Last piece finally arrived
  8. #10268
    Made this for a customer. Rear turbo dump
    Pipe. No more restriction here. Lol and a flash y pipe
    In progress shot.
  9. #10269
    TGC Regular boosting90's Avatar
    05-14-2014
    Central Florida
    426
    Those should work if they're listed for the 3g. I bought the wrong ones long time ago.
    Edit: saw that listing actually has the diameter of the bushing. I'll measure the stock bushings to confirm.
    From searching real quick I found out that the 2g bushings are the same size while 3g and evo uses two sizes. I had it backwards. My bad.
    Fitment is great snogg and tight. Its a go
    Sent from my SM-G386T using Tapatalk
  10. #10270
    05-14-2014
    Central Florida
    426
    Scored found my tranny. 125$$$
  11. #10271
    03-12-2012
    Manvel Texas
    1,171
    Sweet find. Now put it in already.. Lol. Its for your project car, right?
  12. #10272
    05-14-2014
    Central Florida
    426
    Quote Originally Posted by coconut View Post
    Yea for the green one. I dont know if i should. Lol i want lsd and to make sure is in good conditions. The clutch was is gone. As in wearout. So
  13. #10273
    Some stainless bolts for freshness.
  14. #10274
    ^^ Lookin good Trotty!!
    Update on the check engine light, it does have something to do with the exhaust. He said it could be a simple leak or it could have something to do with a charcoal canister?? Also said there is no harm done to the car, it is just a little less efficient.
  15. #10275
    Finally I'm 5 speed swapped. Got the Prothane mounts on the motor and front control arm. Need to figure out how to get the axles out because they are fused into the hubs, wire the the sensors in, and put in the rear Prothanes. Can't wait.
  16. #10276
    Quote Originally Posted by ViewAskew View Post
    Congrats! Let it soak overnight in WD40. I like to leave the ball joint alone and loosen the bolts attaching the hub to the strut. Than gently hammer the axle out with the proper size bolt or pipe and a rubber mallet while turning / pulling away the hub.
  17. #10277
    When it happened to me I got new axles and spindles from the yard.
    I tried it all including heat with a torch.
  18. #10278
    Buy new knuckles from the Mitsubishi dealership, they are cheap cheap cheap! (Seriously! When I had to replace an axle, the replacement knuckle was MUCh cheaper than in the boneyards). Then buy new hubs and axles.
    If that happens again, buy the spindles/knuckles from the Mitsubishi dealership.
  19. #10279
    Horrible pictures be damned, but I had to post this anyways!
  20. #10280
    ^^^ You have two 3 cylinder galants?:D
    They look clean AF!
