Thread: General 8G Question Thread
Page 31 of 33 FirstFirst ... 2127282930313233 LastLast
Showing results 601 to 620 of 650
  1. #601
    IIrc 8g exhausts have 2 resonstors right, and are they straight through or chamber design? I switched from a straight through muffler to a turbo muffler to avoid tickets. Now I find myself wanting a lil more sound, but still be quieter than the straight flow muffler I had. Thinking of removing one resonstor or replacing one with a bullet race muffler and hopefully the additional flow will give more sound, thats if the resonators arent straight design to begin with.
    Thanks fot any input
  2. #602
    Resonators are straight through, its what they're packed with that muffles the sound.
  3. #603
    Was afraid of that. Thanks for responding. I wonder if deleting one will be too loud for my goals. My previous muffler was louder than a g35 and my current turbo style I think is a little quieter than one. Tryna hit the nail on the head in terms of loudness of a stock g35 or a hair louder, I know the exact sound probably wont be duplicated.
    Need to let someone drive my car around in a lot to see where im at in sound currently. Maybe getting a smaller resonstor in length will do the trick but keep rasp down.
  4. #604
    TGC Lifetime Patron Palmz's Avatar
    04-14-2011
    Iceland
    533
    Is this a correct brake setup, It seem wrong to me if you can see the picture you can see the big spring is connected to the lever and the small spring behind is holdeing the pads together i think it should be the other way (yes this is how i opend it up)
    2001 Galant 2.4 USDM
    Old ones
    2X BMW E34 Blaaackkkk
    Isuzu Trooper mountain spec
  5. #605
    Tried to google for threads on here to see if it's been done before, but would a 3g auto knob be a direct fit on 8g w/ no modding?
    Thanks for any input
  6. #606
    No. Not without cutting the plastic piece inside. I also think they sit too high on the galant. Not sure if anyone has pics to compare
  7. #607
    Was afraid of that. Thanks for letting me know
  8. #608
    can i put Cadillac, Audi, Ford, or any other car manufacturer speakers in my 02 galant, as long as they the same dimensions? 6.5" and 6x9 i believe
    Sent from my LGMS345 using Tapatalk
  9. #609
    Quote Originally Posted by ronin View Post
    Positive to positive and negative to negative. As long as the specs are similar and the mounting brackets are similar you should be good to go. 6X9's are kind of a pain to replace imo, the speakers in the door are easy. I would just go buy some aftermarket speakers from best buy or amazon personally, they aren't very expensive.
    1991 Jeep Comanche (SOLD)
    2002 Honda Accord EX (DAILY)
    1998 Eclipse GST (PROJECT)
  10. #610
    You have the standard stereo or the Infinity? Make sure the impedance is matching as well.
  11. #611
    On V6 acceleration vibration issue, are we just doing the washer trick? Anything else that it could be?
    I'm stock height with new axles and the shit is bad. 01 GTZ.
  12. #612
    Not sure I know what the washer trick is
    Sent from my SM-G7102 using Tapatalk
  13. #613
    On the wheel side of the axle you place a washer on the axle spline shaft before it goes through the hub.
  14. #614
    Really? I also have a v6 and wonder if this would help with my vibration issues. I'm assuming there is a tutorial around about that? With sizes and all?
  15. #615
    Yep. Quite common.
  16. #616
    04-14-2011
    Iceland
    533
    What size are the sway "stabilizer" bars in the 01 ES 2.4? 18mm ???!!!??
    Old ones
  17. #617
    Quote Originally Posted by Palmz View Post
    Rear stabilizer bar should be 19mm, and front stabilizer bar should be 17mm, IIRC.
  18. #618
    04-14-2011
    Iceland
    533
    reeeeaaaallllyyyy... hmmmm i thought the front bar was thicker ... ill probly have to measure them tomorow if i get the time
    Old ones
  19. #619
    i believe the GTZ came with the 19mm and the ES came with an 18mm on the back.
    '91 Kawasaki ZX7 (SOLD)
    '95 Kawasaki ZX9R
  20. #620
    I'll measure my OEM rear sway bar when I get home.
