Thread: Galantman03's 8G Build
Page 19 of 70 FirstFirst ... 91516171819202122232969 ... LastLast
Showing results 361 to 380 of 1392
  1. #361
    08-26-2007
    L.I.N.Y./ Rockville MD
    1,148
    i hear ya i would rather have power breaks too.
  2. #362
    I have some questions about the fuel tank. I have 3 Ports in the tank, fill opening, a smaller one I think vent, and then a tiny one.. That's it no emission crap on the tank. And I traced those on the stock tank and it all goes into the fuel filler neck. So if I just match lines up it should work the same correct? Since I wont have emissions, I just want the fill station to stop pumping when it its full that's all lol
  3. #363
    Did a little work today. Getting everything installed to make the cuts on the subframe
    Ran into a snag though, I don't have an engine hoist and what I was planning to use, I don't think it would hold all that weight. So what do you do when you don't have an engine hoist and really don't feel like buying one yet?
    You first position the engine/tranny in the bay from underneath.
    then you remove your support block that are holding up the forward part of the vehicle
    Push down on the radiator support, I kid you not maybe 20 lbs of force..
    And you will bring the engine bay to the engine/tranny...
    Bolt it up, jack the frame back up, and install your support block
  4. #364
    08-04-2003
    NY
    4,344
    If you just use a 2g eclispe AWD filler neck, all the hoses hook up to it like they should and everything works fine. With the 2g neck, one of the bolt holes lines up with the stock 8g filler neck bolt holes (the ones under the car), honestly, that one bolt is more than enough to hold it in, that thing weights like 2 or 3lbs. If you wanted to be extra carefule, you can weld another tab onto the neck underneath so it can utilize the other bolt hole.
    99' Galant ES
    4G64/63T
    AEM EMS
  5. #365
    Thanks for the info. Ill try to look for a new awd filler neck.
  6. #366
    Just a little update...curious if that's enough room between the floor pan and the t case tail, I have 5/8 of an inch between the two. Input?
  7. #367
    08-26-2007
    1,148
    i think Brian had to cut the whole floor out when it was all said and done,,, and werent you scared the car was gonna fall over on the blocks lol.
  8. #368
    I hope not lol, I know he used a bfh. But idk how much the engine really moves under torque.. And nope not really, if it fell I would have been surprised lol, it was way quicker than an engine host, 5 mins to get the engine and tranny mounted lol. I'll do it again
  9. #369
    08-26-2007
    1,148
    you had the fulcrum in te right spot lol.
    i know he cut the outter skin first like you have but it wasnt enough so he removed the airbag module and hammered the hell out of the area but still wasnt satisfied so i think he either spacers on the motor mounts somewhere or cut the floor out, im sure he'll chime in.
  10. #370
    Great progress!
  11. #371
    Coming together nicely. Keep up the good work!
  12. #372
    Quote Originally Posted by xd_01 View Post
    I guess he cut the floor out...but I wonder if there is a difference between years in that area...
    Great progress!
    thanks guys! Its getting there. Did this earlier, i'm going to have to adjust the front left side for the tranny mount. This its just a mock up lol, nothing hits anything.
  13. #373
    Anybody know how far the engine rocks upon WOT? Idk if I like this distance
  14. #374
    Just a thought I would measure from the center of your motor mount to the perimeter of it. Then add the engine into equation itll give you the absolute play possible.
    Great progress so far!
  15. #375
    ok so, this is for stewi or goosey, are you guys running power steering? pros and cons? I have driven a truck with out power steering and it sucks when your not moving, but when your driving, its not to bad..... hmm. I cannot get the nipple on the rack to seal.. the one that you have to relocate..
  16. #376
    working... Sucks waiting for parts... But here are some pics
  17. #377
    Good work so far. Get the 2g filler neck, that's not even an option really and you'll know that once you see the last few photos in my bail thread. And you have to cut the floor under the shifter then fill the gaps with metal and weld. Don't forget to remove the airbag ecu before cutting(right behind the shifter under a controls)? Keep it up!
    Sent from my SAMSUNG-SGH-I777 using Tapatalk 2
  18. #378
    Powrtsteering is a good thing keep it. What do you mean to seal?
  19. #379
    Quote Originally Posted by GOOSEY2099 View Post
    See ok that's what I was worried about. How much room are we talking for the tcase? I have almost 2 inches from using a bfh, from the floor to the tcase, when all four mounts are installed. For the power steering, I tried using a banjo fitting, by tapping the rack, but it wouldn't seal, so I just welded it on lol.
  20. #380
    You should buy -6an steel weld on fittings and weld them to the ps hard line. Then run a -6 line to the pump. And wait till you get a driveshaft and you'll see how much space you really don't have there. Me and Stewi both had to do this and this wasn't cause we like destroying the car lol(or do we... :)
Tags for this Thread
