Thread: Galantman03's 8G Build
Page 50 of 70 FirstFirst ... 4046474849505152535460 ... LastLast
Showing results 981 to 1,000 of 1392
  1. #981
    12-13-2010
    Brooklyn, Maryland
    4,643
    Wow. Chasing that harness issue huh? More power to ya Jared, I don't think I could handle that noise and keep my sanity.
    -Greg
  2. #982
    Yeah its out. Found the issue, but im going to make like 200% sure everything is fricken Golden before i put it back in. With that being sad, what is all 5V sensor wise, im assuming crank cam water temp tps is? Anything else?
    Sent from my DROID RAZR using Tapatalk
  3. #983
    02-17-2011
    i live in sunny florida
    1,240
    danm!!]
    MODS
    5 speed swap
    Eibach Pro Kit on GR2 Struts
    Cold Air Intake
    Outlander Intake Manifold
    6G72 V6 Throttle Body
    6G72 V6 Fuel Pump
    Axle Back Exhaust (ebay)
    Evo Fuel Rail
    Evo Radiator
    Rear Disc Swap
    Prothane Motor Mount Inserts
  4. #984
    I think you got them all Jared. Ugh I'm not envious.
    Sent from my HTC6500LVW using Tapatalk
    The "Tumbler" Is Here
    3xxWHP/3xxWTQ [Current]
  5. #985
    It sucked! I tried to not remove the brace to keep my steering column connected... Yeah that didnt work. As soon as the column fell, i went ape shit on the hvac lol. Oh and i guess i decided to supply 12v to the crank and cam sensor....... Fml lol
  6. #986
    Yeah that damn column has to come out. I hateeeee pulling the dash omg. Lol and yeahhh power and ground issues always happen on harnesses I swear.
  7. #987
    Hooefully the sensors are good.
  8. #988
    I'll swap out the CAM sensor tomorrow on the eclipse to make sure it works, and I'll meter the crank and cam voltage just to make sure and the water temp haha. I'm gonna fricken lose it soon. This nice weather is PERFECT for driving!
  9. #989
    Quote Originally Posted by Ivory8g View Post
    for some reason i enjoy pulling the galants dash out. maybe i have done it so many time that i know exactly what is needed. i can prob have the entire dash, column and crash bar out in an hour if i had all my tools and an extra hand to help me with the crash bar. the only shitty part was maneuvering the heater box with the crash bar in the way but i think i found a trick for that. just havent done it in a while to remember.
  10. #990
    yeah its probably cause ive done it only 3 times so im still not a fan by any means haha
  11. #991
    Bought a dash from the yard not too long a ago it takes me 10 minutes or less to pull it. I was very temped to get one this weekend, it was a pristine gray dash, cushions didnt feel dry and no cracks, car had just got there no dust inside even the the doors were gone.
  12. #992
    I dont mind pulling the dash, but the heater core f that! I'm going to have extra bolts left over i know it lol
  13. #993
    Lmao yeah those damn hoses haha! There is a trick to those things. Until you learn it ugh.
  14. #994
    So I have no idea whats going on. I metered the eclipse I get 12VDC to both the crank and cam sensor, and then that means that they output 5VDC square wave to the ecu. I think I'm going to order both a cam sensor and a crank sensor and just change them. I'm getting fuel, I have power to everything correctly and it won't light off. I might slave in some oem coil packs and just try it, even if they are a little longer than evo ones lol. If I change both sensors, and crank it with OEM coil packs and it still doesn't light off, then its gotta be the ecu.
  15. #995
    youre running an evo harness/ecu?
  16. #996
    Evo ecu with pig tails, galant harness
  17. #997
    Yeah my thinking after all of that its got to be a ground or the ecu
  18. #998
    I checked all the grounds and they either ground in the bay, or go through the ecu and out a specific sensor ground in the ecu. So its all there. Maybe my timing is that off lol, i cant be that lucky. Race car build=race car problems
  19. #999
    hope this helps somewhat. im sure youve got it all figured out as for wiring but hey it doesnt hurt to triple check with a diagram you may have not seen yet.
  20. #1000
    I'm assuming thats an evo schematic?
Tags for this Thread
