Thread: Galantman03's 8G Build
Page 56 of 70 FirstFirst ... 64652535455565758596066 ... LastLast
Showing results 1,101 to 1,120 of 1392
  1. #1101
    You mean like the spring is simply too short? Helper springs?
    Not short I guess, just has some play and idk why.
    Quote Originally Posted by gojirars View Post
    Is the spring rubbing the perch in the slightest? And does your spring come with a "silencer rubber"? Tein makes these and it seemed to help in terms of removing my front end clunking. I have the SS and it has been solid since doing so.
    No, the d2s did not come with any rubber silencer crap.
    Sent from my DROID RAZR using Tapatalk
  2. #1102
    How do the d2s work? My teins preload adjustment and height adjustment are on the same rings so if you set teins all the way down the spring will be loose at full decompression. I believe this is called droop. BC has rings to adjust height via moving the bottom mount up and down and a separate set of rings to set preload in the spring. If d2's are set up this way, could it be possible that one side doesn't have enough preload set as the other?
    Jigz-TGCIL Sosick Motorsports
  3. #1103
    like this lol. maybe they don't even have preload lol hmm.. time to read
  4. #1104
    Fuuuuuuck that's clean
  5. #1105
    Id definitely check the preload because if the spring droops, everytime the coilover assembly decompresses fully the spring will be loose.
  6. #1106
    I would say loose but I can spin the spring fairly easy by hand in the perch... D2 instructions clearly say dont touch the preload, and i have none lol
  7. #1107
    Megans don't come preloaded but basically the instructions says to make sure preload is at 0 which means u can move the spring by hand like yours.
    I have a clunking noise on my driver side that I need to inspect. But on the top of the spring mine has a cap that acts as an isolator which should prevent noise. Maybe yours is missing?? Unless both sides don't have it.
    So is the spring contacting the top pillowball mount directly??
    Sent from my Galaxy S4
    '91 Kawasaki ZX7 (SOLD)
    '95 Kawasaki ZX9R
  8. #1108
    08-26-2007
    L.I.N.Y./ Rockville MD
    1,148
    My JIC's are the same way. The instructions if i remember correctly say not to pre-load them, I leave a very small amount of play like a couple of mm's worth. Enough so I can still spin the coil with my hand muchike yours and Spdrcer.
  9. #1109
    so how do I quiet them down if they didn't come with the rubber crap? I really don't want to take them apart...
  10. #1110
    05-03-2009
    Aguadilla, Puerto Rico
    1,465
    My D2's are set so I can spin the springs by hand but the instructions say to make sure they don't have any up and down play, thats how mine are setup. Maybe try to find some kind of rubber to put around the coil like jigz said about the teins, or give them a slight preload, so you have absolutely no play at the spring.
    4g64T 5spd
  11. #1111
    08-26-2007
    1,148
    Once I sprayed it with wd40 and another time I lined it with some type of grease but it did nothing so I just it ignore it now. Sorry I know this doesnt help.
  12. #1112
    Can u get a diagram of them broken down?? I know Megan racing has that on their site showing all the different components of the full assembly. I'm curious to see yours and compare them.
    '95 Kawasaki ZX9R
  13. #1113
    Two rounds tighter than just touching the spring, front and back. Keep it's tight and quiet and a smidge more firm.
    I've set up a number of cars this way, clocked over 100k on DDed cars (one with 55k and a few winters alone) and a few track days annually, nothing too serious though. No issues at all, the ones I've taken off for people have been in better shape than the used sets others buy and want put in. The ride is firm but more than manageable given the ideals coilover users follow. Just can't drive too much with a full bladder.
    I have no installation experience with BC's but I've done the above with D2's, Megans and Ksports.
  14. #1114
    Thanks man, Ill give that a shot.
  15. #1115
    10-24-2003
    1,432
    I use a set of digital calipers and make sure to set them to the same height, I get them to where they are resistant to turn by hand, not loose, not stiff, but turnable with resistance.
    The best way is to do that and then corner balance, but that gets it very close if your ride height is adjusted right.
    www.gooichimotorsports.com
  16. #1116
  17. #1117
    Thanks Guys! Means alot. I just wish I had a fellow galant owner so I could cruise with lol. I had a whole parking lot of "fast cars" turn and watch me as I drove passed, and even a couple bikes whipped out and tried to get me to go chill in the parking lot with them. Not down with that, Im a loner. Plus most those guys are base faggots anyways LOL
    You could have a few Galant owners to cruise with if you moved down to FL :)
  18. #1118
    03-12-2012
    Manvel Texas
    1,171
    Or to Cali
  19. #1119
    Need some input. Car runs fantastic in vac. As soon as I even go to 0 vac or into boost a little, car leans WAY Out, so bad it cuts out. Can't even do a pull into boost, very frustrating. Fuel system is good I checked all of it. I'm speed density, but what all factors into the ecu to adjust fuel? I'm going to bench test my AEM 5 bar tomorrow, but if that's good, where else to look? It's not the tune btw, he tried the ROM on someone else, no issues. Only 2 codes btw, knock sensor circuit 1 and iat sensor circuit 1, but the all meter to the ecu fine. Need some more ideas...
  20. #1120
    This is obvious but wouldnt hurt to try. Have you done a boost leak test yet? Normally a boost leak will have rich conditions in boost or WOT. But I have seen skittles run lean due to a boost leak.
Tags for this Thread
