Thread: Galantman03's 8G Build
Page 59 of 70 FirstFirst ... 94955565758596061626369 ... LastLast
Showing results 1,161 to 1,180 of 1392
  1. #1161
    Mine is at -12 272 cam
    That's because it's made by RPW.
  2. #1162
    I have a feeling that nobody will know what I am talking about but its worth a shot I guess. The connectors in the engine bay, like injectors, cam, crank sensor, does anybody know what brand they are? I know that the evo ecu plugs are tyco and I can get that information on evom, but nobody on there even mentions the plugs. Basically I am going to redo the harness and make it completely hidden, but I'm not going to solder or use splices. I'm going to depin, repin, crimp and run all new wires from the sensors themselves to the firewall connections. I was hoping that maybe somebody knows the brand or knows where I can find the info for it?
  3. #1163
    12-13-2010
    Brooklyn, Maryland
    4,643
    Wish I knew. I just looked at mine, couldn't figure anything out.
    Edit: a quick search shows KUM/Sumitomo connectors that look like ours, but nothing definitive.
    -Greg
  4. #1164
    This is some of the hardest info to find honestly. Back in the day spd_frk and I searched for a while. I believe they were Tyco. We found the pins for ecu side as well as several of the engine side connectors when we were making harnesses. I think I still have it in a binder somewhere I'll check and see for you J.
    The "Tumbler" Is Here
    3xxWHP/3xxWTQ [Current]
  5. #1165
    I guess I can go look at the connectors and see if there is anything stamped on them like cannon plugs have, but I'm pretty sure they don't have any NSN or part number on them. hmm
    Quote Originally Posted by Ivory8g View Post
    Dude, that would be tits! haha
  6. #1166
    So all my parts come next week, which sadly means I will be missing the last autocross of the season... :( Other then that, still working on some things. But I will leave you with this picture, because it snowed, and its probably going to stay in the garage all winter long. That's me btw, and my dad lol
  7. #1167
    How do you feel owning a sick ride? lol your car looks beast
  8. #1168
    The rare photo of owner and car! Your g looks so mean
  9. #1169
    08-08-2004
    Las Vegas
    2,099
    chase bay seems to use new plugs so they must be available. our oem harness uses almost all the same connectors on the engine side of the harness as an evo/2g so between these three sites i think you can get everything you need.
    ecu plugs and pins
    http://evoecu.logic.net/wiki/Plugs,_...and_Connectors
    engine related plugs and pins
    http://connectors.sheridanengineering.com/index-2.htm
    also engine related plugs and pins
    http://www.szabaga.com/store/diyconn.html
    or you could buy a chase bay harness
    http://www.evolutionm.net/forums/evo...ltech-com.html
  10. #1170
    Quote Originally Posted by Exhaust power View Post
    Just like all of us on the forum, a proud galant owner man! But its a blast to drive, cause nobody expects this thing to be that fast.
    Where is your pic or car and driver? wink wink! lol. I think it could be a little meaner IMO.. winter time... haha
    Quote Originally Posted by underated View Post
    ecu plugs and pins
    You know whats nice? I found everything, EXCEPT the IAC and the front 02 connector. Thanks to your links, I have found the IAC, but I still need to find the front 02. I'll just take out the pins and see if those pins are used anywhere else. Thanks for the links man!
    And NO don't use chase bays, IMO they have no idea what they are doing as far as a MIL-SPEC harness. They probably don't even know how to properly lace a harness. Oh well. This winter I will make a tut on wire tucking and mils-spec info.
    Also, hopefully this winter I will be able to take care of the little stuff. IE interior and what not.
  11. #1171
    08-08-2004
    Las Vegas
    2,099
    isnt this the front oxygen sensor connector
    http://connectors.sheridanengineering.com/NMWP4F-B.htm
    this site also has a lot of good stuff
    http://www.bmotorsports.com/shop/
  12. #1172
    it is but it doesn't help me if I can't order it.
    I have all the info I need for the pins, I just have to go out an see if I can track down some info on the besides the names that all these websites give out. I need to find the manufacturer and their code to order them for like 5 cents a piece, compared to 75 cents each, if you know what I mean haha
  13. #1173
    08-08-2004
    Las Vegas
    2,099
    im confused why can't you order it?
  14. #1174
    I can... I fail at reading this entire week apparently.
  15. #1175
    08-08-2004
    Las Vegas
    2,099
    haha its all good man i'll try and look for the connectors from the make but they usually have a minimum order per piece could be 5,10,50,100,500 ect. i would just pull the connectors from a junkyard galant/eclipse pocket them and buy new pins for everything
  16. #1176
    As of right now I don't need any connectors, and I broke a couple from the 3 or 4 harnesses that I have trying to get the pins out haha. I have to see how the connectors work, and now I know for sure on all the ones that I have to removed. The only PIN/ contact that I CANNOT locate is the stupid starter one. Its a weird looking female spade, I might have to save it some how.
  17. #1177
    08-08-2004
    Las Vegas
    2,099
    are you talking about the one for the solenoid?
    http://www.repairconnector.com/packa...ousing-5-pack/
    the "pin" is in the discription
  18. #1178
    You're good. That's it.
    Sent from my DROID RAZR using Tapatalk
  19. #1179
    08-08-2004
    Las Vegas
    2,099
    glad i could help its something i want to do also so i had some of the research done
  20. #1180
    I'm watching this closely. I'd love to make a full harness to eliminate this mess in the engine bay. I don't mind pinning new plugs and running wires between connectors.
    U better make this tutorial with part numbers to plugs!
    Sent from my Galaxy S4
    '91 Kawasaki ZX7 (SOLD)
    '95 Kawasaki ZX9R
Tags for this Thread
