New Member
no but really dohh, you still have you're factory amp?
I just installed mine about 2 weeks ago and what I did is I got the scoche wiring kit and then put one end around the positive (make sure your negative is out before attempting anything....) Then I had to remove the battery from the car and then pull back some of the firewall insulation. From the inside of the car where the clutch would be if there was one was a little hole with a screw's end facing toward us (so that you could unscrew it) So I slowly drilled a little bit bigger each time till the wire could fit through. Then I just lifted the panels up and went through the whole car. Up until I got the the back seat. Went under that and to the amp. Then from the amp I used the RCA and the turn on and went on the otherside of the car and got those panels up. If you still need more help I will post some pics when I do it again in a couple of days for my second amp.
