Showing results 1 to 4 of 4
    Monroe OESpectrum struts - review
    Hey guys, just wanted to share that I recently installed new Monroe OESpectrum ( OE Spectrum ) struts on my GTZ.
    I had previously run the OEM struts, then a set of KYB GR2 struts.
    I am happy with the OESpectrums and really cannot tell a difference between them and either the OEM or GR2s.
    Hope that helps.....
    Quick question, are you lowered or using gtz springs???
    GTZ springs.....OE equipment
    OE Spectrum series come with the same exact sturt that came in the car from factory. so you can say they are OEM without the mitsu part number on them. at least that is what the rep from monroe told me when he visited my store at advance auto.
    Fully Built 4G63
    HKS 272
    ported Dual Ball Bearing FP RED 84mm 25psi w/ external dump
