Thread: Cleaned Throttle body and IAC problem?
Showing results 1 to 20 of 21
    Cleaned Throttle body and now Idle problem?
    My throttle body was all gunked and sticking so I removed it to clean it. I removed the idle air control motor before cleaning and only cleaned it with a cloth wet with carb cleaner. Put everything back together and now it idles @ 1500 RPM. Is there a trick to resetting the IAC or installing it. It idled fine before.
    I just reset the computer (disconnected the battery for 10 mins) and no change. I also put a light coat of lithium grease on the IAC O-ring in case it was leaking (can't buy it separate). Anyone who is replacing their IAC be careful what you buy, I noticed that the BWD brand does not come with the o-ring. Hell, for that much $ it should install itself.
    2002 ES, V6, 140K
    No there is not a trick to setting the iac in,what did it idle at before you cleaned it?
    800 RPM. I only cleaned the TB because it was sticking and dirty. I found an IAC @ Rock Auto for $220 but I may try a junk yard first.
    2002 ES, V6, 140K
    Quote Originally Posted by shadow83 View Post
    yeah i would try and find a used one ebay might have a oem one
    07-12-2007
    SoCal
    4,632
    I had this problem before. The IAC control sensors are VERY sensitive. If you get any amount of cleaner on the sensor or touch the tip of it, you will have issues. My mistake was not removing the sensor when I cleaned my TB, and the dirt and solvent made contact with the sensor and fried it. Try finding one at a junkyard first, thats what I did. Bcz those sensors are expensive everywhere...
    JDM Zenki Conversion
    06-13-2008
    Bronx, NY
    2,606
    You need to drive around 100 miles so the PCM could relearn the new readings. Also let it idle for 14 min.
    SOHC Turbo
    I done the same thing as you and mine won't idle, stall at un predictable times. Some mornings it starts and idles ok and sometimes it don't? But I didn't take out the iac valve and sprayed the shit out of it. And fucked it up.
    I've done this to the "T" it don't work, and what's up with the 14min.? Why not round to 15min.?
    Quote Originally Posted by Hevymetalg View Post
    Yeah you dont want to get the iac wet,thats why when you clean them you wipe it off with a dry,clean rag with nothing on it.
    Too late for me!! :)
    I have to agree. If you let anything touch that IAC, forget it, its toast. Even though it looks dirty as all get out, its still fully functional, till you cleaned it
    Picked up two from a U-Pull-it yard for $8 each and idled even higher, they were from a 4 cyl (could not find a V6 in the yard) but the TB is the same. I ordered a new IAC since that seems like all it can be, a $230 gamble. Has anyone ever had a bad IAC and no code is thrown?
    Note to all: The Felpro fibre gasket has the tab opposite of the OEM copper gasket so when you install it do not use the listed orientation in the shop manual. When I read the shop manual and it stressed where the gasket tab should be I pulled it apart and changed it and no good. I even reinstalled the factory copper gasket just in case the Felpro was not correct and nada.
    2002 ES, V6, 140K
    I have had a bad iac and no code was thrown it just didnt want to run right and wanted to stall all the time.
    I take that you have a V6? the TB are not the same, I have swaped to the 6g72 tb and now to the 6g74, the 72 has the same connectors, but its not the same size. also if you put a 4 cylinder iac in a V6 TB, your going to idle high. I tried putting the I4 IAC in the V6 TB on a I4 and it idle way higher.
    neonwhiteandbluegalant
    car wont start after timing adjustments cleand the tb
    hi im new here me and my dad got a 2000 mitsubishi galant 2.4l 4g64 i replaced the engine head bcuz the story i heard it got overheated not to worry bout that now i got the timing marks lined up and still no spark or fire i cleaned the tb and havnt checkd the IAC unit not sure if its fine or that has anything to do with it not firing it cood b the alternator but sounds like electrical problems i just need help and facts wat it cood b
    If your not getting spark it's not the alt. and def. not the idle control...hmm... Are you getting any spark?
    Sent from god
    No spark, I would start with the ignition coils and their connectors as well as spark plugs. Then move from there, I know that there is some cars that won;t spark if the camshaft sensor is bad.
    Bronx NYC (reppin)
    3,489
    Damn, $230! I would have sold you a brand new one for like $175
    Drive It Like You Stole It!
    7G Erubini Body Kit for sale
    did you ever fix the idle problem?
    Yes. It was my TPS. I did not remove it when I cleaned the throttle body.
    2002 ES, V6, 140K
