Thread: very high idle speed
Showing results 1 to 10 of 10
    Icon5 very high idle speed
    my 2003 galant es 4 cyl w/auto has a very fast idle(2500rpm or plus) in the morning or after sitting for several hours: when the engine and coolant are cool. It goes to normal approx 700rpm after a few minutes when the engine temp starts rising. I checked the BISS and it was less than one turn loose; i turned it in and now it seems stuck, won't back out. I also replaced the CTS and i thought that fixed it, but the same issue returned. I tried disconnecting the battery cable for a few hours and that made no difference and also checked for codes with my code reader;there are no pending or stored codes(obviously no check engine light). This car has 107000 trouble free highway miles. Any ideas?
    12-13-2010
    Brooklyn, Maryland
    4,646
    Isaurio responded to your question in the other post you put it in, but I'll reiterate: That's supposed to happen. Gets your engine up to temp faster, gets your exhaust up to temp faster so your catalyst can work and your fuel system can go closed loop. It's all good, don't make anymore changes, she's good to go! Hope this helps.
    -Greg
    thanks, but it never used to do idle this high 2500rpm+; plus if i put it in drive, its dangerous as it wants to leap forward.
    03-16-2010
    Maplewood, NJ
    1,290
    That seems about right, my car has a high idle when i first start after its sat for a couple hours. Once the engine is warm, the idle drops to normal idle. I think all cars are like that.
    i don't know why my car never used to fast idle this high before, it was always like 1800-2000 tops. now its 2500+ rpm for a few minutes
    12-13-2010
    Brooklyn, Maryland
    4,646
    Quote Originally Posted by gman956 View Post
    How long have you had the car?
    -Greg
    can you send me a link to where you said Isaurio replied to my other post? THANKS
    12-13-2010
    Brooklyn, Maryland
    4,646
    http://www.thegalantcenter.org/showp...9&postcount=10
    Also, have you changed oil brands, done a tune-up etc. recently or in the last few months? I ask because when I switched from mineral oil to synthetic, I noticed my cold idle jumped from no higher than 1500 rpm to between 2000-2500 rpm. It's getting colder, so you may notice an increase in cold idle speed around this time of year.
    -Greg
    The only thing i did was add a quart of Lucas trans conditioner to the tranny about 2 months ago.
