Thread: I am NOT going to spill anything in this thread
Page 6 of 11 FirstFirst ... 2345678910 ... LastLast
Showing results 101 to 120 of 214
  1. #101
    nsk makes the OEM bearing. I have the screen shots from ASA and the manufactures to prove it. But there are 2 types a plastic inner or a metal inner
    Gotcha. I got it wrong then. Where did u get it from for that cheap??
    '91 Kawasaki ZX7 (SOLD)
    '95 Kawasaki ZX9R
  2. #102
    11-29-2009
    Chadds Ford, PA
    2,768
    Autoanything
  3. #103
    11-29-2009
    Chadds Ford, PA
    2,768
    Subframe by slammedsedan, on Flickr
  4. #104
    12-13-2010
    Brooklyn, Maryland
    4,643
    ...aaand we're back on it!!
    -Greg
  5. #105
    11-29-2009
    Chadds Ford, PA
    2,768
    20141117_143105 by slammedsedan, on Flickr
    20141117_143125 by slammedsedan, on Flickr
    Started prepping the awd control arms for bushings and paint. Working on the rear subframe later tonight.
  6. #106
    12-13-2010
    Brooklyn, Maryland
    4,643
    Oh snap!
    -Greg
  7. #107
    TGC Regular boosting90's Avatar
    05-14-2014
    Central Florida
    426
    subscribe!!!!!
    just the thought of s monster allmotor awd
    i know it will be turbo. too much weight to pull N/A
    nice setup love the compression
  8. #108
    Nice work....waiting patiently for updates
  9. #109
    11-29-2009
    Chadds Ford, PA
    2,768
    Wont be all motor. Numbers I have crunched have put the compression ratio north of 11.0. So some work will need to be done to fix this, most likely shaving the pistons down. W-2 came in so hoping to buy coilovers within the month. Will be the first to have this brand adapted to the car. Fingers crossed.
  10. #110
    05-14-2014
    Central Florida
    426
    u still can run boost at tht compression. but is all about timing and rich tunning and low boost. people do get scare of high compression boost. yea i know is risky but is fun and response is increible. but really hoping u figure ur setup out and reach ur specs. dont keep us in the dark. lol
  11. #111
    11-29-2009
    Chadds Ford, PA
    2,768
    So I wrecked my audi now I need a car. So the plan is dump a ton of money into this project to get bare minimal dd status.
    Prepping the bay for paint and primer.
    spherical rear toe arms.
    Cams and Jdm 3 bar map sensor
  12. #112
    05-14-2014
    Central Florida
    426
    tht sucks. Hope wasnt to bad (accident) dang It i was hoping to have another high compression boost galant. Hopefully is not to far in the future tht u get back on build. But priorities are always more important.
    Engine back stayin sliver?
  13. #113
    11-29-2009
    Chadds Ford, PA
    2,768
    Negative, but like I said I dont talk till its done.
    Sent some suspension measurements out and hoping to send payment by the end of the week.
  14. #114
    11-29-2009
    Chadds Ford, PA
    2,768
    Ams 880cc injectors. Basically rebranded pte injectors.
    New core support and mishimoto evo 5 radiator. Since there is very little aftermarket support for this car I have to adapt other model parts to it. The evo 5 radiator top outlet is 8 inches to the left which places it closer to the inlet on the head.
    But it can't be just a bolt in affair. Not sure whether I am having the pegs moved or making new mounts on the core support.
    Porting out the head. Gasket matching the intake, smoothing the ports, removing the sharp lips near the valve seat, and all that jazz.
    This is only the first pass with 80 grit.
    Also knife edging the divider this port still needs some work before the final grits.
  15. #115
    i just saw this saying that you wanna get this to a dd status. what r the plans to make it run and what is your anticipated completion date ?
    '95 Kawasaki ZX9R
  16. #116
    11-29-2009
    Chadds Ford, PA
    2,768
    Basically keep plugging along buying tons of parts. Goal is running by June. Fully driving by July.
  17. #117
    Awd??
    '95 Kawasaki ZX9R
  18. #118
    11-29-2009
    Chadds Ford, PA
    2,768
    Nope fwd out the gate. Then awd
  19. #119
    Ok this makes sense.
    '95 Kawasaki ZX9R
  20. #120
    11-29-2009
    Chadds Ford, PA
    2,768
    20150503_223555 by slammedsedan, on Flickr
    Evo 8 oil filter housing, going to run a oil cooler, and turbo feed from here.
    20150501_151635 by slammedsedan, on Flickr
    20150503_172447 by slammedsedan, on Flickr
    Gauge pod with wideband and boost gauge
    20150502_231158_001 by slammedsedan, on Flickr
    Evo 8 turbo with 10.5t hotside. Considering getting the kinugwa 20g wheel and compressor housing.
