Check engine light on? You could have damaged the maf and could have damaged the FIAV or IAC with the liquid
Hi
I was having some idling problems when car was cold rpms would go crazy up and down up and down so i bought some maf cleaner and throttle cleaner. Cleaned the maf and throttle body but now car wont start, my guess is that since i cleaned the throttle without removing it that sone cleaner went thru the the holes. Any ideas what to try??? thanks
2014 Lancer Evo GSR
1996 Galant S 5 Speed Turbo
Check engine light have been on since forever lol
Check obvious stuff first. Are all the electrical connections plugged back in correctly? Any big air gaps? Does it start at all?
Well i left the car for a few hours with every hose disconected to kinda let it dry better, tried again and car started theres deffinetly an improvement on the idle but idle is still a bit crazy. Going to leave it like that for a while. Thanks a lot for your help guys
Go get your engine codes read and find out what else is wrong.
Might be your IAC.
Since you cleaned the TB, you might have to adjust the BISS screw. Turn it just a little and see how the car responds. Just remember where you started when you do it. Worked for me...
Sent from my LG-P925 using Tapatalk
-Andrew
