You should be good, I'm running 17x8 with 45 offset
so here's the deal.
I've got a 2003 Mitsubishi Galant Es that i got some rims for, im having trouble figuring out what tire size i need to put on them that wont rub the crap out of my ride.
The rim size is 17x7.5 with a 45mm off set.
just in case you need more info on the rims, the link below is them.
http://www.andysautosport.com/custom...c=RPMW00159724
ok, so the rims will work. sweet. any idea what size tire i'd need to put on it?
Great, thanks alot dude.
and one more thing, if said rims and tires were put on the car, how far do you think i could lower it before i ran into trouble?
you've got a gtz, your suspension is a little different from mine i believe, and i dont think youd have a problem. not so sure about my es.
id like to roll my fenders just for the heck of it anyway, i dont mind it.
why would anyone roll fenders on a stock setup?
That question was for the OP I know your setup which may require fender rolls for the drop.
