Thread: Project Bodega Beige
Page 18 of 32 FirstFirst ... 814151617181920212228 ... LastLast
Showing results 341 to 360 of 629
  1. #341
    05-14-2010
    Coachella, CA
    5,954
    Shortest route is drilling through the firewall and installing a grommet for saftey.
  2. #342
    I think I fed mine with the harness grommet.
    I did more work. Evo5 radiator installed. Had to test my welding skills to make the bottom work. Also installed the timing belt. Just need to install the auto tensioner and pull the pin. Still need to wire in the resistor pack since I switched from STI injectors to evo fic 1050cc
    '91 Kawasaki ZX7 (SOLD)
    '95 Kawasaki ZX9R
  3. #343
    Experienced TGC Member
    03-12-2012
    Manvel Texas
    1,171
    Coming along beautifully.. Loving it!!
  4. #344
    Had to buy a 2001 Dodge neon upper radiator hose to make the evo5 radiator work #MoparPower
    Bottom hose I used the stock one and just cut it shorter.
    '95 Kawasaki ZX9R
  5. #345
    Nice progress.
    Wellyes, I just had a hard time finding a good spot to go through with the thick cable I'm running. On a second thought, I have a parts car and the interior is pulled already... time to get the drill out.
  6. #346
    Spent the last 3 days finishing it. Cut out a plate for the COP from acrylic using the router at work.
    Unlike many people who did the swap and said that the cam sensor needs to be extended and so does few other sensors, I unwrapped the harness and got enough slack for all the sensors to route them to their new location. I used an evo crank position sensor and it's so long that it goes over the valve cover and sits next to the fuel rail so that helped me about extending the plug for it.
    I will do another session for the full harness clean up.
    First start up I had a fuel leak from the feed line. Found out the o-ring was pinched. Replaced it and it ran fine.
    Coolant temp sensor connector was broken so I had to fix it since I didn't have a spare
    My gf bought me a stage 4 6puck disc for the car as a birthday gift
    Working on wiring the injectors and the resistor pack and then the ignition coils
    Before
    After
    Here an idle video
    '95 Kawasaki ZX9R
  7. #347
    Experienced TGC Member xd_01's Avatar
    08-26-2007
    L.I.N.Y./ Rockville MD
    1,148
    Looks good, when will it be ready for the track?
  8. #348
    Still lots of tuning to do. I'm having an issue with the map sensor. I also don't wanna run it down the strip until I get two slicks and an LSD for it. I really really wanna run it but I'll just spin tires through the gears lol
    '95 Kawasaki ZX9R
  9. #349
  10. #350
    ^^lol. Idle sounds good. Like how that neon hose lined up like it was meant to be
  11. #351
    I'm having idle issues. Car is running super rich. No matter how much fuel we pulled it is still rich.
    Checked the crank and cam sensors. As well as swapped the map sensor and all functioning. Gonna check voltage at the injectors and if that checks out then I need to swap back to sti injectors to see if that works. Compression test is also on the list.
    '95 Kawasaki ZX9R
  12. #352
    Swapped back to sti injectors and no luck. I'm gonna borrow a spare evo fpr and test.
    '95 Kawasaki ZX9R
  13. #353
    how long are the injectors staying open?
  14. #354
    Not sure. Injectors aren't faulty. There was a suspicion that the ecu is fried cuz the resistor pack is bad. Well confirmed that my resistor pack is fine. Gonna swap ecu anyway and test both ecus against each other.
    '95 Kawasaki ZX9R
  15. #355
    the reason i ask is because on most cars in current/live data you can watch the injector pulse time. usually its around 700miliseconds. obviously if theyre staying open too long then that could be a reason. just a long shot but it could be causing it
  16. #356
    Quote Originally Posted by kylecanthurdle View Post
    I didn't mean to reply short. I was just in a rush and couldn't sit and write an essay. The car at this point won't even start and idle. If I open the throttle all the way while cranking then I manage to get it to run but it's dumping fuel like crazy.
    '95 Kawasaki ZX9R
  17. #357
    It's definitely not the injectors cuz I swapped back to my sti injectors and it made no difference. So not sure what's causing it.
    '95 Kawasaki ZX9R
  18. #358
    The ecu was bad. I borrowed another ecu and the car ran.
    '95 Kawasaki ZX9R
  19. #359
    '95 Kawasaki ZX9R
  20. #360
    03-12-2012
    Manvel Texas
    1,171
    Man that is so beautiful. Make me want to start collecting parts for a swap.
