Thread: Project Bodega Beige
Page 16 of 32 FirstFirst ... 612131415161718192026 ... LastLast
Showing results 301 to 320 of 629
  1. #301
    OH tell me more about this gasket?
    Well we grew up in the same neighborhood and hung out all the time when we were younger!! Oh wait that's not what u wanted to know lol
    '91 Kawasaki ZX7 (SOLD)
    '95 Kawasaki ZX9R
  2. #302
    I hate you. Just like my mom when I say I'm going to the gym. "who's Jim?"
  3. #303
    Lol you asked for it!!!
    '95 Kawasaki ZX9R
  4. #304
    08-26-2007
    L.I.N.Y./ Rockville MD
    1,148
    I had the same problem with the oil leaking from the turbine sound of the housing. Turns out I just overfilled like a dumbass.
  5. #305
    Overfill it how??
    '95 Kawasaki ZX9R
  6. #306
    08-26-2007
    1,148
    Well over the winter I took off the oil cooler and added a sandwich plate to the oil filter bracket for some sensors, I never fully drained the oil so between the extra 2 qts the accusump holds plus the kick out on the oil pan I missed judge how much I needed to refill according to the dipstick. Ill be honest Im not exactly sure where I went wrong and It might have been having the mind set that I need to add enough to fill the cooler also but in the end I disconnected the return line from the pan to see if it was clogged and oil just kept pouring out. I probably drained about 2 qts when it stopped draining and then check the dip stick and I only needed to re-fill about 1/2qt.
    So I did that but I only filled up to the first line on the stick which indicates your about a qt low but I have enough capacity to do that. Im asking myself now do I really need have the cooler full all the times, does it actually get full when WOT, did this contribute to me overfilling, luckily it only ran in the garage so Im sure it didn't effect anything.
    I gotta find out because Im planning on using an cooler on the trans now since I have issues with blowing 4th and need to know if I have to add extra gear oil since theoreticly there will be less in the trans while it running through the cooling system.
  7. #307
    I would definitely add more oil to the cooler. It's the same concept of the radiator. U need to get that air bubble out. At least that's how I see it. I will be adding a cooler to mine some time later this summer so I will find out more info on it.
    As far as over filling I don't have your issue.
    I have a straight fitting going into a 45 and that's causing an unneeded kink in the link due to the tight radius reducing the diameter of the tube at the very middle of it. So another 45 at the turbo side should make it flow better.
    '95 Kawasaki ZX9R
  8. #308
    08-26-2007
    1,148
    I actually have the same set up, strate fitting at the oil pan and 45 at the turbo but i dont have a kink. I face the 45 towards the radiator with a slight turn to the right and sweeps in towards the oil pan over the dpif I remember correctly.
    Mines is a -10 though, PTE recomended to me a -12 but I never been able to find a drain fitting that sizr.
  9. #309
    I sourced a 12an for the holset. Only one source sells it and it's in Canada. I paid $50 for both turbo and oil pan fittings. I think the placement of my turbo gives me that kink and yours doesn't. I had a - 10 with two 45 on each end but I felt that was restricting the flow and causing the turbo to leak from the compressor side so I swapped to a 12an. Let me dig up the source I bought it from and post the link for u.
    '95 Kawasaki ZX9R
  10. #310
    '95 Kawasaki ZX9R
  11. #311
    08-26-2007
    1,148
    Nice, thanks!
  12. #312
    You're welcome. I decided to go with push lock hose instead of stainless line. Much easier to assemble.
    '95 Kawasaki ZX9R
  13. #313
    I have bought a lot of four 12an to 3/4" npt to fit those.
    http://pages.ebay.com/motors/link/?n...775162&alt=web
    '95 Kawasaki ZX9R
  14. #314
    Head is back from the machinist. Valves and valve seats all cut. Resurfaced it. Cleaned it. Installed evo valves and retainers along with the HKS 280s.
    '95 Kawasaki ZX9R
  15. #315
    Head is out!!
    '95 Kawasaki ZX9R
  16. #316
    Did some work today. Cleaned the block. Installed the head studs. Connected the intake manifold to the head, installed new reluctor and sealed the housing. Installed the fidanza cam gears. Routed all the vacuum lines on the intake manifold properly.
    '95 Kawasaki ZX9R
  17. #317
    03-12-2012
    Manvel Texas
    1,171
    Oh im loving this
    Good work.
  18. #318
    Quote Originally Posted by coconut View Post
    Oh im loving this
    Good work.
    Thank you. More pics to come. I need to rewire the tps and wire in the new injector plugs. Remove the old timing belt since I cut it to for quick head removal. And install all the new timing belt pulleys.
    '95 Kawasaki ZX9R
  19. #319
    03-12-2012
    Manvel Texas
    1,171
    Man, your making me want to do that turbo set up on mine following your build.. Ill be happy with 7lbs of boost.
  20. #320
    Do it. A healthy 4g64 can handle some decent boost. Wait until I finish the head swap. I'm planning on cranking up the boost.
    '95 Kawasaki ZX9R
