Thread: Project Bodega Beige
Page 20 of 32 FirstFirst ... 1016171819202122232430 ... LastLast
Showing results 381 to 400 of 629
  1. #381
    Yeah that's what I was running into.
    Jigz-TGCIL Sosick Motorsports
  2. #382
    Hmmm. I need to get an evo lower and upper covers and mess around with them.
    '91 Kawasaki ZX7 (SOLD)
    '95 Kawasaki ZX9R
  3. #383
    Brian posted this on evolutionm:
    Originally Posted by VTEC Killer
    None of them from the mitsu's fully line up. I just have a piece of heavy duty shipping tape covering the seam so no debris gets in there. The only motor that I think the timing cover might work is like a 03-05 Kia Optima or Hyundai Sonata since those 2.4 motors came DOHC from the factory. Im not sure if they use a two or 3 piece design or not. I know the mitsu 4G64 lower cover from the Galant or Eclipse definetly doesnt work.
    '95 Kawasaki ZX9R
  4. #384
    I have compared the sonata upper to evo upper and sonata lower to evo lower. i think the sonata upper cover is a bit longer to meet the bottom cover due to the longer deck height.
    lower sonata cover has some bolt holes that don't match the evo/galant covers but those are in the middle and the main important ones to me are the outer ones.
    upper and lower sonata covers are $58 shipped on amazon. total was $64ish with tax. i will install them and take pics. i believe this should work with good fitment making up for the gap that the evo cover creates
    '95 Kawasaki ZX9R
  5. #385
    03-12-2012
    Manvel Texas
    1,171
    Time to get some custom made..
  6. #386
    Most people care for the lower cover and leave the upper off. I wanna just experiment to see if the sonata upper and bottom fit perfectly or not. Plus I need a lower cover to replace the galant one. I may end up using the top cover. Not sure yet.
    '95 Kawasaki ZX9R
  7. #387
    when i get into my welding class ill see what can be done to get some proper fitting covers. Im allready working with plexi so i might be able to do a metal cover wit plexi windows to see through. not sure what term welding starts at though im in steering & under carriage right now.
  8. #388
    U need to have the setup I have in order to make something for it. Otherwise giving you dimensions will be a bitch.
    '95 Kawasaki ZX9R
  9. #389
    08-26-2007
    L.I.N.Y./ Rockville MD
    1,148
    I have the evo lower cover and Zaklee clear cover up top, its tru that it isnt a perfect fit but the top bolts line up fine and I used some zipties on the bottom holes. Even the though lower holes dont line up it still fits fine once its zipped up and there hard to see unless your really looking for it.
    I know you want a perfect fit but honestly this works fine and not worth the hassle in my opinion. You can use that effort elsewhere.
    Coming along nicely!!
  10. #390
    Quote Originally Posted by xd_01 View Post
    Thanks Bryant, I'm gonna fiddle around with the sonata parts. The cost of both top and bottom sonata covers were less than a stock lower evo one so that justified it for me right now. Maybe later down the road I can switch covers or see if the zaklee will fit with the sonata lower. Small gap isn't a major issue for me honestly and using zip ties definitely not a problem either lol
    Brian did say his top one cracked from the vibration of the solid mounts. So I have to think about it lol
    '95 Kawasaki ZX9R
  11. #391
    08-26-2007
    1,148
    I haven't had any issues with cracking and Im on urethane mounts as well with a bit of track time with the car. Maybe its just one of those things.
    Either way my main reason for having a clear cover is to keep an eye on the adjustable cam gears, Im always worried there gonna back off with all the vibrations. I drew lines with a sharpie on the face of the gear next to the fasteners and across the fastener head. If it starts to back out those sharpie lines will be misaligned and Ill cath it before its to late. I do checks before and after each session and this is one of them. The clear cover is a good investment.
  12. #392
    Yeah its definitely good to keep an eye on those. I'm not a huge fan of the design of the fidanza gears and I really feel like the Aem Tru time gears are a safer option since they use bigger bolts.
    '95 Kawasaki ZX9R
  13. #393
    What about the galant gs timing top cover?
  14. #394
    I made a pure assumption that it is different due to the different shape of the valve cover. This assumption was made based on my first assumption that it's the same valve cover as a dsm.
    '95 Kawasaki ZX9R
  15. #395
    Sorry I ment bottom cover haha
  16. #396
    A wild guess says that it won't line up to our oil pump.
    '95 Kawasaki ZX9R
  17. #397
    Aaron runs top and bottom sonata and he said they work. He just had to shave the inside of the cover since it rubs on the cam gears.
    '95 Kawasaki ZX9R
  18. #398
    I have the evo bottom and evo clear up top. I just zip tied the two holes that didn't match. I'm honestly never going to run my clear cover again
  19. #399
    Sent you a message.
    '95 Kawasaki ZX9R
  20. #400
    Techna-fit trimmed the hose and sent it back. Now if they sent me the right power steering rack fitting then I would finish my power steering lines but no they sent me another fitting for the pump. On a good note this routes perfectly how I planned it. Just need to install some hose clamps to secure those lines in place and done.
    '95 Kawasaki ZX9R
