Thread: Project Bodega Beige
Page 22 of 32 FirstFirst ... 12181920212223242526 ... LastLast
Showing results 421 to 440 of 629
  1. #421
    Doing some tuning this week at 14psi. This is a ballpark power graph.
    Going up to 22psi next.
    '91 Kawasaki ZX7 (SOLD)
    '95 Kawasaki ZX9R
  2. #422
    08-26-2007
    L.I.N.Y./ Rockville MD
    1,148
    22 psi is wheel spin category from a dig for the 8g. Start low and see what point you break loose too easily then adjust from there. Tire compound, air pressure and weight transfer play a big role.
    GL!!
  3. #423
    Quote Originally Posted by xd_01 View Post
    GL!!
    We r gonna tune it for that high and then drop the boost down. So it's there if needed. Doubt I'm gonna run 22psi at the track honestly. Not without an LSD and some grippy tires at least.
    '95 Kawasaki ZX9R
  4. #424
    That graph I posted wasn't so good. Did another one last one and the tuner did more adjustment and went our again tonight.
    This is from last night
    This is from tonight
    Then this happened lol
    '95 Kawasaki ZX9R
  5. #425
    03-12-2012
    Manvel Texas
    1,171
    Awesome numbers and that sucks about the cable.
  6. #426
    08-26-2007
    1,148
    Thats pretty good and damn that sucks about the cable. same thing happened to me 2 yrs ago when I went to the dyno.
  7. #427
    Sourced a replacement cable and installed it.
    Here is where it broke
    Now I need to route my alternator power cable to the trunk and mount a battery kill switch before Saturday morning.
    '95 Kawasaki ZX9R
  8. #428
    Went to the local track Friday to get some launches before I head to Englishtown on Saturday to race. Got to Atco and I was leaking from the turbo return line. The bolt backed out from vibration. Spent two hours fixing it and only ran once after that. Ran 15.05 with a 99mph trap.
    Saturday we drove to Englishtown and same thing happened. Spent two hours fixing it. This time we needed a gasket so we user a romantic novel cover and a longer bolt from my friends Volkswagen. Made it work and ran once and ran a 13.90
    Went back today to the local track for IFO and there was a ton of hondas running. Didn't get there till late because I fixed the fitting. Replaced the two bolts with longer ones and use lock washers and made a new gasket and used rtv.
    My push lock hose was leaking so I replaced it with a different hose and now it's leak free
    Only ran twice today. B two bad runs. 15.4 and 16.3 I dropped the tire pressure and it made my launch worse. I just need know practice.
    This is how she sits now
    Threw the car on the scale with a good amount of tools in the trunk and It weighed 3175 and without the tools I came down to 3090 without me in it.
    '95 Kawasaki ZX9R
  9. #429
    Here's the video from Englishtown
    http://s233.photobucket.com/user/spd...dezdo.mp4.html
    '95 Kawasaki ZX9R
  10. #430
  11. #431
    Quote Originally Posted by gtx View Post
    Nice! You are going to love that LSD once you get it.
    I can't wait till I get one but that won't be till next spring probably along with drag radials. But I will continue to tune for more power in the mean time.
    '95 Kawasaki ZX9R
  12. #432
    This is from the track yesterday
    '95 Kawasaki ZX9R
  13. #433
    Nice job on that 13.90 and the romance novel gasket lol, thats some quick thinking.
  14. #434
    Time to relocate my gauges.
    This is the old location. It was never finished and I hate the position.
    I bought this universal 3 gauge pod and going to try to mold it on the A-pillar
    '95 Kawasaki ZX9R
  15. #435
    Pulled the oil pan so I can reseal it since it's leaking. I found metal shavings on my oil. After further inspection I found that the center main bearing spun and the others are scored.
    The car will be down all winter doing a rebuild slowly. I'm rebuilding a spare block with forged internals.
    Middle bearing
    End bearing
    Crank
    '95 Kawasaki ZX9R
  16. #436
    08-26-2007
    1,148
    Ouch, this was stock bottom right?
  17. #437
    Yes that was a stock bottom. I'm not entirely sure what caused it to do this though.
    '95 Kawasaki ZX9R
  18. #438
    Ouch, always something! Forces you to do a good thing tho.
  19. #439
    Yeah its just not time for it. I will slowly build the block over the winter and hopefully be ready by the spring.
    '95 Kawasaki ZX9R
  20. #440
    08-26-2007
    1,148
    That sucks, have you considered another stock bottom?
