Thread: Project Bodega Beige
Page 23 of 32 FirstFirst ... 13192021222324252627 ... LastLast
Showing results 441 to 460 of 629
  1. #441
    Quote Originally Posted by xd_01 View Post
    That sucks, have you considered another stock bottom?
    I have one in storage from my old daily with 175k but I tore it down today to inspect the crank lol.
    I have been holding on to these for years.
    No sense in uploading all 8 pics of all rods and pistons lol.
    '91 Kawasaki ZX7 (SOLD)
    '95 Kawasaki ZX9R
  2. #442
    lol do it do it!
  3. #443
    lol do it do it!
    I bought the pistons used years ago. Have minor scratches I can buff out. But according to my scale (which doesn't have fractions) one piston and one wrist pin is way off from the rest. Once I get a better scale I will confirm the weight and then decide weather I wanna pay to get the last piston shaved to match or buy a new one.
    '95 Kawasaki ZX9R
  4. #444
    see if they can balance the rotating assembly
  5. #445
    Not many machine shops around here. I'll consider it as an option depending on the price.
    '95 Kawasaki ZX9R
  6. #446
    08-26-2007
    L.I.N.Y./ Rockville MD
    1,148
    look like wiseco and eagles
  7. #447
    Manley and eagle
    '95 Kawasaki ZX9R
  8. #448
    Weighed the rods and pistons to have an idea of how much apart they are
    Had a talk with Manley. The heavy piston and light wrist pin are getting replaced with another one to match the rest then I'll balance them to the lightest one. I bought then used and I think the previous owner had the work done by a shop so I think they may have replaced a piston for whatever reason.
    '95 Kawasaki ZX9R
  9. #449
    How do you like the balance shaft delete? How bad does the engine vibrate now? Poly bushings aside
    Sent from my SM-G925T using Tapatalk
  10. #450
    06-13-2008
    Bronx, NY
    2,606
    Yeah. No balance shaft poly motor mounts. Yeah. Vibration on a daily. Need to put locktie on every single bolt. If not. Say good bye to them.
    SOHC Turbo
  11. #451
    I have poly mounts on the way. Contemplating balance shaft delete, but I don't want the engine shaking so bad it feels like a misfire or something. Is the balance shaft delete worth it?
  12. #452
    06-13-2008
    Bronx, NY
    2,606
    It depends. On your goals. It will vibrate for sure if is a daily you wont like it. The delete will eliminate that famous balance belt that always goes if not keep on checked. And will free up more rotating capability and lb. But like i said it depends on your goals.
    SOHC Turbo
  13. #453
    Honestly my goal right now is just to get it running lol. The next goal is just a little more get up and go. But I have the engine out now so figured it's a good time to delete them. I don't have plans for anything crazy
  14. #454
    It's really not that bad. I have my motor solid mounted with those deleted and dash vibrates. Could be because I have no bushings on the front end. It's tolerable. If you do do it at least balance the internals
  15. #455
    For non turbo applications it's no power gains.
    '95 Kawasaki ZX9R
  16. #456
    The reason my oil return came loose twice is because the balance shaft delete accompanied with poly mounts and the slightly heavier cams.
    Like isaurio said. Locktite is your friend after a balance shaft delete and poly mounts.
    '95 Kawasaki ZX9R
  17. #457
    Well since I have no immediate plans for forced induction, I'll hold off for now. I have to wait and see the condition of my new engine so I can see what still needs to be ordered. So far I just ordered plugs, wires, mounts, timing belt, and a clutch kit
  18. #458
    Engine is out and in pieces.
    '95 Kawasaki ZX9R
  19. #459
    03-12-2012
    Manvel Texas
    1,171
    Poor car.
  20. #460
    Small update:
    Took the block and head and crank to the shop. Head has cracked valve guides. Cranks must be cut due to heavy scratches.
    I went back to him with my other block and other head. Block is getting bored so it's getting punched 0.020" over.
    Changing the Manley low compression pistons and going with a set of Wiseco pistons to give me a 9.5:1 CR instead.
    '95 Kawasaki ZX9R
