Which one? Small one or big one?
-Roman
I'm getting my water pump done and taking care of leaks. But the pulley is also knocking side to side most of the time and it's becoming annoying. Someone told me I can only get it at the dealer. If anyone knows elsewhere I can pick one up for cheap that would be a lot of help.
-Roman
I got one, brand new $10+3shipping
Paypal:[email protected]
-Roman
Does not make sense that your pulley is knocking from side to side unless one of the following is true; you are missing a couple of the pulley to water pump mounting bolts (not likely) or the shaft of the water pump itself is bad (most likely cause). Regardless what the cause of the knocking from side to side is if you are replacing the water pump that should enable you to fix it without replacing the pulley. I'd replace the pulley only it is damaged from being knocked about.
jjj
^Ding Ding Ding
