EGR and Purge Solonoid hose connections? -Outlander swap
I'm ready to put my outlander IM on BUT I've got a service manual that does NOT have any information regarding what plugs into the EGR. What this service Manual says (btw it's from Prophet's 8th gen service manual thread) is that the purge solenoid connects to the IM and then to chamber hose and doesn't give any information regarding the EGR. As if having the EGR bolted to the IM was enough lol It has 2 connections on it that need to be plugged in for it to function.
I'm thinking the EGR and the Purge both connect to each other but I'm not sure in what order? The egr must go to the purge and the chamber hose connects to the egr? Or the IM hose coming from the purge goes on the egr and purge also connects to the egr, then the purge connects to the chamber hose? Theres a spare short hose in this mess the connects the egr and purge I believe.
There has to be a way to complete the circuit I took a video too which I'll upload.
