Are you having any other issues with it? Headlights dimming when brakes pressed? Does the idle go up when you turn on the A/C? Checked for vacuum leaks? Is the idle consistently low or does it bounce around and try to stall?
Seems like IAC (Idle Air Control) issues are common on these cars, I just went round and round with mine for the past few months and finally got it sorted after a $30 trip to Pick N Pull.
Also just dealt with a low idle issue which seems to have been a ground cable issue (fingers crossed). Just replaced that yesterday and reseated all the ground lines I could find after cleaning everything up. Idle was rock solid 850 last night and all the way in to work today, so my hope is that's a done deal.
Some really good, knowledgeable folks on this forum so hopefully you can get some help to sort it out.
